Sponsored by: CARiD
Key won't turn, steering wheel stuck - help!
Old Aug 23, 2009 | 03:57 PM
db8gsr's Avatar
i was leaving work today and i had a little bit of trouble starting my 94 toyota pickup because the key did want to turn. i got home and was going to go to the store and it didnt want to start again. then i turned the wheel so now the steering wheel is stuck also. someone please help i need my truck for work tmrw.
Old Aug 23, 2009 | 04:04 PM
yotainprogress's Avatar
sounds like the steering wheel or ignition is in a bind try pulling the steering wheel hard toward the drivers door while trying to turn the key. The key in my 87 does the same thing from time to time this usually works though I have yet to find the true problem.
Old Aug 23, 2009 | 04:05 PM
myyota's Avatar
The key part of the ignition switch can wear out after years of use, try spraying a little PB Blaster or WD40 into the key hole and see if that helps, if not then you might need to have the key cylinder replaced.
Old Aug 23, 2009 | 04:07 PM
Fink's Avatar
Try jiggling the key in the ignition while gently jiggling the steering wheel back and forth.
I usually just the jiggle the crap out of both of them until the key turns - sounds like you need a new key or your ignition cylinder is worn down or both.
Also, next time, a thread with an ambiguous title like this is just going to get deleted.
You have to put more in it than just help so people can find it later when searching.
Good luck,
Fink
Old Aug 23, 2009 | 04:25 PM
db8gsr's Avatar
tried jiggling the crap out of it, not working. how do i get the ignition out of the aluminum housing properly?
Old Aug 23, 2009 | 07:49 PM
db8gsr's Avatar
anyone know where to get the ignition cylinder, how much these cost, and how to replace it??
Old Aug 23, 2009 | 07:50 PM
desertcamper67's Avatar
That is going to be ugly. I'm pretty sure you're going to have to kind of bust it apart. Its not made to come apart easliy.
Old Aug 23, 2009 | 07:51 PM
I've got one at the junk yard with a key in it. I had to carry a door AND ignition key.
Old Aug 24, 2009 | 12:59 PM
db8gsr's Avatar
anyone got one forsale? how do i remove the old one?
Old Aug 24, 2009 | 01:10 PM
bigt's Avatar
i bet you juse have to wiggle the wheel harder sometimes on a old yota id have to almost put my foot into it lol. go back and forth with key while going left and right on wheel with otehr hand
Old Aug 24, 2009 | 01:13 PM
badattitude's Avatar
Try turning the key over, make sense? This happens to me and I just flip the key and it works. Is you key worn or even a copy?
Old Aug 24, 2009 | 02:16 PM
murdarunna19's Avatar
yeah just wiggle it harder pulling the wheel towards the drivers side while turning the key.
-matt
Old Aug 29, 2009 | 10:48 AM
4gen5thtime's Avatar
Try putting some graphite in there. It works wonders shoot a bunch in there and coat the key with it. Then slide the key in and out a few times and coat it and shoot more in, then try turning it. Almost every car I've ever had this problem with it fixes it. Graphite pwns 95% of stuck locks I've came across the other 5% we just had to cut or replace.
Old Aug 29, 2009 | 11:25 AM
mallardtape's Avatar
graphite is only a temporary fix if it works which many times it does. you will need the lock cylinder replaced
Old Aug 29, 2009 | 02:00 PM
graphite isnt really a temp fix, its more of a should be done thing. You are susposed to lube(which graphite does) locks, hinges and greese certs often which most people never do. Call around to locksmiths and ask them about graphite..
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
raiderhawks00
Jul 8, 2015 06:23 PM
