Sponsored by: CARiD
t/c question
Old Aug 14, 2009 | 08:46 AM
Built2Grind's Avatar
Question t/c question
i want to run a dual stick setup from marlin crawler(they are out of stock right now) it got me thinking about all the people saying they have 15 or 20 speed transmissions when they run the dual case. my question is can i run the low 4 in any gear or can i only run it in first?
Old Aug 14, 2009 | 08:49 AM
904_runner's Avatar
you have any gearing you want.
you have the 5 forward gears and 1 reverse in 2hi. you have 5 forward gears and 1 reverse running in 4-lo, 5 forward and 1 reverse in double low, and 5 forward and 1 reverse in trip low (if you do dual ultimate crawler setup)
So that 20 forward gears, 4 reverse gears.. Its all about the gearing..
Old Aug 14, 2009 | 09:09 AM
dropzone's Avatar
Fossilized
so by referring to a dual stick set up it sounds to me that you are referring to a twinstick which will allow you to have 2WD high and low range and 4WD high/low range.
advantage is that if you have a locker up front you can disengage 4WD when you bind an axle and prevent breakage:
a twin stick set up will not give you any more gear selection with out adding a TC
Dual transfer cases will net you 20 forward and 4 reverse (mine is twinsticks with 4.7 gears in the rear case and stock 2.28 in the front case) 220:1 double low range:
and some folks go dual transmissions:
http://pirate4x4.com/forum/showthread.php?t=698521
Old Aug 14, 2009 | 09:14 AM
alright thanks, i just wanted to know if i could run the t/c low gears throught all the transmission gears, thanks
Old Aug 14, 2009 | 09:46 AM
scuba's Avatar
THATS FREAKING AWESOME !
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
