Sponsored by: CARiD
What PSi????
Old Aug 13, 2009 | 01:15 AM
McQuaid's Avatar
What PSi????
What PSi do you guys run your tyres at?? im doing 90% road driving and have got BFG Mud terrains 325/60 15's...need some advice on what to put in them??
Old Aug 13, 2009 | 03:15 AM
91 4Runner's Avatar
325 60 15 = 30.4" so I would say run 35psi, but that is subjective. I mean my 33x12.5R15 indicate that it's 35psi max pressure, but there is no way I'd run that much due to the narrow stock alloy rims. I run 25 to 26 psi to maintain a flat footprint, But this also has a large impact on MPG.
Hope this helps!
Larry
Old Aug 13, 2009 | 05:20 AM
TNRabbit's Avatar
I usually run front (4x4 3vze XtraCab) @ 38 psi & rear @ 30 psi with no load. That gets me the most even wear.
Old Aug 13, 2009 | 05:27 AM
WatsonToyota's Avatar
35 fronts, 32 rears, summer driving
Old Aug 13, 2009 | 06:12 AM
Ardent's Avatar
I run mine at 27 psi front and rear. Seems to have the most even contact for the tread so that I don't wear out just the middle. Search the chalk method. Essentially the best way to tell is to draw a line on each tire with chalk. Drive a mile or two and you'll see where the wear is going to occur, and you can adjust the pressure accordingly.
Old Aug 13, 2009 | 04:56 PM
FredTJ's Avatar
Originally Posted by 91 4Runner
<SNIP> I mean my 33x12.5R15 indicate that it's 35psi max pressure, but there is no way I'd run that much due to the narrow stock alloy rims. I run 25 to 26 psi to maintain a flat footprint, But this also has a large impact on MPG.
Hope this helps!
Larry
The max pressure that is shown on the sidewall is the max pressure with the maximum load in the vehicle.
Fred
89fourrunner
Feb 17, 2016 06:52 AM
TACOJO
Nov 27, 2015 05:26 PM
old87yota
Oct 25, 2015 02:15 PM
alexcarey
Oct 14, 2015 06:05 PM
travisamorgan
Sep 2, 2015 01:00 PM
