Sponsored by: CARiD
Help me with ideas and got some info
Old Jul 26, 2009 | 12:11 AM
gomerjr's Avatar
anyway i got a 22re toyota pick up ext cab 4x4 and i wanna get mroe power ialready got the k and n air filter what other little things can i do please let me know also here is a helpful story to everyone with efi airflow sensor fuelpump and injector problems that they cant figure out whats wrong
well recently i bought a toyota pickup i took my first long trip and it broke down now i have a 1992 toyota pick up 22re 4x4 ext cab with 80000 i said 80000 miles wel anyway we could not figure out what was wrong i was blowing efi fuses then it woulkd stop and not start and then this would happen and that so we made sure i had fuel and everything etc and everything was there so after replaceing my fuel pump and air flow sensor we found that my battary finally died from not running and trying to start so much so we went to jump my batary and well still got nothing so i waited and hour or so went back out and started just messing around with the key boom smoke started pooring out i had found it the cause to my problems if you have a 22re you are farmiliar with the air flow sensor and the conector into this if you follow that back right by your egr valve you will see there is a nice piece of wireing harness which should be up off your engine and on a bracket there mine however was touching my block when i took that long trip it finally heated it up and cause the short which caused us a month long mouse chase im sure this has happend to othere people and may be now so i fugered id help you there..
Old Jul 26, 2009 | 04:01 PM
myyota's Avatar
A header and exhaust will help some, and you can replace the cam, but don`t expect alot from these engines with just bolt on stuff, there not made for high horse power. but if set up properly with the right gears and things like that, then they do just fine.
Old Jul 26, 2009 | 10:45 PM
Jay351's Avatar
Grab some 4.88 gears from a 92-95 pickup or 4runner with a v6, auto and 31" tires. Direct bolt in, your 22re will love you!!
Old Jul 27, 2009 | 10:12 AM
gomerjr's Avatar
sounds good but i have a 5spd?? so will that work im not sure how those gears and stuff work and what do they do??
Old Jul 30, 2009 | 05:14 PM
forwardtocharis's Avatar
First off, Welcome to Yota Tech.
The 4.88s are with the differential inside the axle housing. They adjust the ratio of drive shaft spin to wheel spin and are typically used when putting on larger tires.
I think 4.88 is recommended for 33-35", anyone wanna verify that?
A bigger exhaust will help you the most, but the cost to benefit ratio of these things is pretty low. If you have the tools and know-how to do all the work yourself then you can get by without spending to much. The other option, if you want more power, is an engine swap.
Use the search, there are lot of articles on performance, swaps, all sorts of things.
I had a problem similar to yours, replaced the fuel filter and who knows what else... stupid AFM was shorting out, a wire shorted on the body. It was from wear though, nor heat.
Old Jul 30, 2009 | 05:30 PM
BigBluePile's Avatar
Welcome to Yotatech!!!
There's TONS of info here to help you get the most outta your truck!!
icentropy
Sep 16, 2020 02:47 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
o2raybid
Sep 4, 2015 12:45 PM
Up&Down
Aug 11, 2015 10:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
