Sponsored by: CARiD
92 4runner v6 auto incline problem
Old May 17, 2012 | 03:21 PM
HIGH_MTN's Avatar
I've read similar problems to this but never had a solution to follow up on...my runner after driving up the mtns for awhile somehow loses all power. The speed just drops even if I manually down shift with floored gas peddle it feels like I'm being dragged to a stop. If I pull over and shut the car off or while its doing that I shut it off then restart its normal again for a few minutes of driving then does the same thing. Car does not have any codes only does this uphill on steep inclines. Have replaced fuel pump/filter cap rotor plugs no vacuum leaks cleaned egr timings on the mark. Any helpful solutions welcomed
Old May 17, 2012 | 04:16 PM
rattlewagon's Avatar
Clogged cat?
Old May 17, 2012 | 04:18 PM
HIGH_MTN's Avatar
Forgot to say o2 sensor is good and cat is new
Old May 17, 2012 | 04:43 PM
wyoming9's Avatar
Just curious how much gas is in your tank?? Did you need to replace the fuel pump bracket??
Have you had this since new??
Has it always done this but only on uphill grades??
it runs fine on the highway at normal speeds?
Old May 17, 2012 | 08:28 PM
HIGH_MTN's Avatar
happens on inclines full or half tank and changed everything that came with the denso fuel pump..miles 255000
Old May 17, 2012 | 11:10 PM
wyoming9's Avatar
Wink
Have you checked the fuel pressure with a gauge??
I am thinking if this was electrical you would have a power loss at all times.
Old May 18, 2012 | 01:02 PM
HIGH_MTN's Avatar
Well ck that when I have time thanks
Old Jun 3, 2012 | 01:14 PM
HIGH_MTN's Avatar
Well finally ckd everything. Comes out as FSM so I guess ill just wait n c how this season well be like when I start going back up to the hills.
TheBFA
Feb 15, 2020 06:55 AM
SpookyMulder
Nov 4, 2015 11:56 AM
Flightguy
Oct 2, 2015 05:34 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
