Sponsored by: CARiD
brake problems
Old Jun 19, 2012 | 08:32 PM
russ70's Avatar
brake problems
Ok just bought my first toyota 3 months ago is an 85 4wd extra cab. The brake pedal will pump up and have resistance with the truck not running but when I start it the pedal goes to the floor and dose not regain any resistence the truck will stop but I have to push the pedal to the floor. I have replaced the master cylinder and bleed the lines and there is no change. Any help would be greatly appreciated.
Thanks
Russ
Old Jun 19, 2012 | 08:55 PM
warmonger88's Avatar
I had the same problem with my 72'. I ended up being that the booster was bad from the master cylinder leaking onto the face of it. After I replaced it, bench bled the new master, and then the lines, everyting worked again. It took months for mine to finally go out completely, but when it did, even pumping them or slamming the pedal to the floor, did nothing. $30 bucks at a junkyard is definately worth it.
Old Jun 19, 2012 | 09:07 PM
russ70's Avatar
That's what I figured was wrong with gonna put a new one in tomorrow I jyst thought I would run it by some people that have more experience with toyotas
Old Jun 20, 2012 | 06:52 AM
waskillywabbit's Avatar
Bench bleed the MC? Bleed the LSPV?
:wabbit2:
Old Jun 20, 2012 | 09:46 AM
russ70's Avatar
Yes I bency bleed the mc and bleed the the valve in the rear
Old Jun 20, 2012 | 11:03 AM
Wsa there fluid between the mc and booster?
Old Jun 20, 2012 | 11:38 AM
russ70's Avatar
Yes there was
Old Jun 20, 2012 | 06:15 PM
russ70's Avatar
Thanks for the help it was the break booster
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
