Sponsored by: CARiD
After Compression Test, Code 12
Old May 15, 2012 | 10:40 PM
ksti's Avatar
Hey everybody,
I finally got around to doing a compression check on my 94 pick up 3vze.
I did disconnect cold start injector plug and distributor plug and had throttle open. The numbers on the dry test were low, so i didn't even bother doing a wet test.
Re-installed plugs buttoned it back up and ran jumper just to check for codes and got a code 12. Read as many threads but i'm a little confused-----Open or short NE circuit or STA or ECM. I re-traced my steps and didn't see anything I left unpluged or broke off. I'm completely stumped why I got this code now.
Any help is always appreciated.
Old May 16, 2012 | 07:18 AM
ksti's Avatar
So I checked the timing this morning and noticed that the timing mark is irattic not alot but not staying on the mark. Pondering if magnets on distributor are weak. I also read something about possible ignitor. Just don't want to start throwing parts at it. Will do some more checking after work.
Old May 17, 2012 | 07:37 AM
ksti's Avatar
Checked wiring last night, couldn't find anything wrong. Starts and runs ok. Tried to clear code just in case, but will not clear. Maybe find a used dizzy and throw it at the truck and see if that helps. A little frustrated right now. Maybe just walk away from it right now and re-think diagnosis.
Old Jun 1, 2012 | 08:08 PM
ksti's Avatar
So I thought I'd post myself again. Had a code 12 and finally had some time tonight to trace some wiring and found 2 wires going to dizzy frayed enough to create short. Repaired wires just on the edge of wire loom cover exiting to dizzy connector. Re-set timing and she's all good again. Even with low compression it still runs pretty good. Ya just gotta keep looking till you find it. No parts toss, no $$$ spent, awesome!.
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
raptor510
Aug 19, 2015 02:15 PM
Sidherish
Aug 2, 2015 01:42 PM
