Sponsored by: CARiD
Oil Smells Like Gas
Old Apr 29, 2012 | 11:07 AM
Row1's Avatar
Oil Smells Like Gas
Was changing my oil in my truck (1990 pickup w/ 22re engine) this afternoon and noticed that the oil had the smell of gasoline in it. Any ideas?
Thanks.
Old Apr 29, 2012 | 11:11 AM
Elton's Avatar
might be a bad injector id hold off driving it tell you figure it out
Old Apr 29, 2012 | 11:36 AM
TICK2791's Avatar
Do you drive it often? Long trips or short? What type thermostat? There are a lot of variables.Does it run well or way rich?
Old Apr 29, 2012 | 11:53 AM
Row1's Avatar
I drive it to and from work 5 days a week, about 20 miles each way. It has been running fine, although about a week ago I noticed it sputtering a bit on the highway right after I put some gas in the tank. As soon as that gas was gone, the sputter went away, so I attributed it to some bad fuel. As far as the thermostat goes, I'm not certain. I have not touched it in the 5 years I have owned the truck.
Thanks for your input.
Old Apr 29, 2012 | 02:41 PM
rokblok's Avatar
Oil creates hydrocarbons(HC) as it breaks down. If it was 3K mile+ oil that was well overdue to be changed, i would change oil and filter and run it for a few miles, check it again.
Though It's possible you have a leaky injector that lets fuel drip into cylinder when it's not running, and maybe seep past rings, and into the crankcase.
There are lots of variables and possibilities...
Old Apr 29, 2012 | 06:00 PM
Kiroshu's Avatar
A rich running condition lets unburned fuel passed the rings....
-So does a miss fire
-So does bad gas
-So does a leaking Cold Start injector
-So does a leaking Fuel injector
Also the more worn the piston rings are the more fuel and combustion gases "blow-by" the rings even when and or if the engine is operating fine.
(High Mileage Engine)
Stuck open thermostat.
Faulty Coolant Temperature sensor.
Incorrect Burn time(Ignition timing/spark plugs)
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
skoti89
Sep 11, 2015 07:46 AM
ryerye13
Jul 14, 2015 08:27 AM
