Sponsored by: CARiD
92 4runner pesky problem
Old May 17, 2012 | 01:22 PM
HIGH_MTN's Avatar
Ok first post ever after 5-6 months of reading forums....
My v6 auto 4runner has a problem I cant find. It does not do it everyday it only does it out of the blue. It feels like the engine dies for a split second ck engine flashes once then its running fine again while driving. Has no codes have replaced cap rotor plugs fuel pump and filter ckd timing. My cars running like a champ except that problem
Old May 17, 2012 | 01:36 PM
BMcEL's Avatar
Check the stored code. Procedure is in the diagnostics section of the FSM. Link below.
Old May 17, 2012 | 01:41 PM
motocrossaddict223's Avatar
could be...dun dun dun ...knock sensor :'(..mine did this exact thing a few times then the light was just constantly on and i got absolutely no mpg and no power. But you probably need to check the code first because the knock sensor is quite a job to replace.
Old May 17, 2012 | 01:42 PM
93toyrunner2's Avatar
Loose grounds in engine compartment (3)? Loose ECM mount bolts, loss of ground behind kick panel. Bad ground for ignition switch? Bad or brittle wiring at Coil& Ignitor and/or Distributor? All locations can be found in the FSM, link in my signature.
Old May 17, 2012 | 02:02 PM
HIGH_MTN's Avatar
Thanks for the fast replies will ck grounds
Old Jun 3, 2012 | 01:17 PM
HIGH_MTN's Avatar
Well everything I ckd is good. This beats me so I'm giving up ill just drive it like this. I can live with it aslong as it doesn't get worst.
Old Jun 3, 2012 | 04:29 PM
Team420's Avatar
Are your battery terminals nice and tight? My rig would do the same thing if I didnt crank those things nice and tight... It can also happen with too much corrosion.
Old Jun 21, 2012 | 01:04 PM
HIGH_MTN's Avatar
Yep battery terminals are tight n clean..
I've had my car for a year its only occurred 5 times, its ok ill keep on driving it as long as it doesn't do it everyday I'm fine
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
