Sponsored by: CARiD
bent back to crank case pulley
Old Jun 15, 2012 | 07:41 AM
thefishguy77's Avatar
I just pulled off my crank case pulley and found the PO used a screw driver to get it off at one time. the "cup, cone" on the back has noticeable pry marks. I have never seen this before and am wondering if it can be reused. here is a picture to show how bad it is bent.
sorry if this is a duplicate question. I asked it in my timing chain thread but thought I would just start a new one specific to the bent pulley. could this cause a big leak if the oil pump seal is still good?
Thanks
Old Jun 15, 2012 | 09:04 AM
41 looks and no reply. please help I can go pull another pulley off my 89 parts truck but don't want to unless it is needed.
Old Jun 15, 2012 | 09:41 AM
rworegon's Avatar
Was it on there like that with no problems? If so, I'd be tempted to use it.
Does that bungered surface actually make contact with the oil seal? Could you carefully flatten out the bent up section a bit?
Old Jun 15, 2012 | 09:57 AM
85TurboRunner's Avatar
Its just a dust shield, it doesn't contact anything. bend it back and forget about it.
Old Jun 16, 2012 | 10:19 AM
thank you for all the help I bent it back the best I could. I will put it back on and close it up.
thanks again
bigjstang
Jun 2, 2025 03:56 PM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
elwood73
Jul 5, 2015 07:07 AM
