Sponsored by: CARiD
2" higher on the left side?
Old May 21, 2012 | 01:28 PM
bezrq surf's Avatar
My diff went together easily even after welding the truss and gussets on it. And the guy who did it burned it on with stick and no cool down breaks
I finally finished my swap and my front left hand
Side sits 2" higher then the right side?
It bugs me alot!
My shackle angle is the same front and rear and it measures
22" to the bottom of my front leafs? I can only assume bent diff But maybe some one would know better! Wabbit??? Hehe
Old May 21, 2012 | 02:53 PM
lobukbuild's Avatar
when u did the work did u have the springs out? if you did u might of put them in on the wrong side. the left and right springs can be different to compensate for the 3rd member being off center. it is also posible u could have them or one in backwards. when u did the welding did u get any of the springs hot while u had wieght on them because that could cause the spring to sag. one last thing did u have any shims or spacers between the axle and springs that might of got mixed up.
jasonty
41
Dec 23, 2018 01:00 PM
shisha1999
Jul 13, 2015 11:09 PM
crashburnoveride
Jul 10, 2015 06:39 AM
garagespace
Jul 9, 2015 08:37 AM
Nickdigg
Jul 7, 2015 06:04 AM
