Sponsored by: CARiD
Need leaf spring help
Old Jun 1, 2012 | 10:34 AM
Baraged's Avatar
I want to switch from 3in hd tg 47 inch springs to a 52 inch chevy rear spring in the front . My bump stops don't line up they are off about 3in . ....any input would be helpful .
Old Jun 1, 2012 | 11:59 AM
rattlewagon's Avatar
Got any pics of what your trying to do?
Most likely you'll have to cut off the old bumpstop and re-weld it in the correct location.
And Welcome to YT!
Old Jun 1, 2012 | 12:24 PM
ChefYota4x4's Avatar
I have no clue... but YES, WELCOME TO YOTATECH! Don't worry, you'll get people to chime in on how to approach this properly. I have seen a few HUNDRED threads on here where guys were struggling with which springs/leaf packs, etc., .... and MANY of them had "SOLVED" posts... but never bookmarked em... Still haven't found my SFA donor rig! lol.
Best wishes, Baraged!
Old Jun 1, 2012 | 01:11 PM
Baraged's Avatar
The 4runner currently has 47in long 3in hd tg lift springs the springs seem too short the shackles are inverted and axel is pushed forward and the bump stops are off about 2 1/2in . I talked to the guys that built the truck and it was a reputable shop they informed me that it should have 4in tg flex springs wich are 47in as well so at this Piont I'm COMPLETLY confused !!!
Old Jun 1, 2012 | 06:17 PM
85TurboRunner's Avatar
Can ya get a pic of whats going on?
I'm assuming they installed and aftermarket front spring hanger, probably a trail gear.
Did they have to cut out shackle hanger holes or is your 4runner an 85?
Your spring hanger could be too far forward if it is an aftermarket one.
Old Jun 1, 2012 | 06:29 PM
Baraged's Avatar
Rear shackles are mounted to the bottom of the frame no holes and front mounts are pushed forward about 3/4 in as recommended for the 4 and 5 inch tg flex springs so I'm hoping it's as easy as swapping the 3in springs for the 4in flex spring . I've come to the conclusion that the 52's will be to long with out moving anything
Old Jun 1, 2012 | 07:45 PM
87 Deathtrap's Avatar
The front shackles should be mounted through the frame, not below it. Whereabouts are they welded on below the frame? The issue could be as simple as them being mounted too far rearward. Pics would really help. Also, anytime that the axle is relocated, the bumpstops will need to be moved to line up.
The 52's can be done, but you will need a pretty long shackle to maintain an acceptable shackle angle. I run 51" springs in front with a 7" shackle.
Old Jun 1, 2012 | 09:40 PM
This
Sounds like your reputable shop was cutting corners.
What makes you think swapping in springs that are the exact same length will fix your problem?
Old Jun 2, 2012 | 02:32 AM
Baraged's Avatar
Wasn't my reputable shop I purchased it this way I'm just trying to get it right .....the guy that owned the truck turned a few wrench on the truck that he shouldn't have is what I think the biggest problem is .....but I think your right the shackle should be through the frame but I'm not sure this sas kit was for a 3rd gen trail gear doesn't list one for a 3rd gen I think it goes up to a 95 2nd gen and then there is a taco sas kit maybe this is why they are mounted on the bottom instead of through the frame ??? In not sure ??? The shackles are pretty close to the bend of the frame though ......
Old Jun 2, 2012 | 02:36 AM
Baraged's Avatar
As for pics I can't upload them from my phone
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
