Sponsored by: CARiD
driveshaft question
Old Jun 1, 2012 | 09:11 PM
possum34's Avatar
driveshaft question
I was wondering if a rear driveshaft out of a 86 extra cab 4x4 shortbed with automatic transmission would fit in my 85 extra cab 4x4 shortbed with 5 speed? I know the bolts will line up but i didnt know if they changed anything up since the went with ifs.I also wasnt sure on the driveshaft length in standard transmission vs. auto.
Old Jun 2, 2012 | 12:14 AM
wyoming9's Avatar
Wink
I think the automatic one is longer compared to the manual one.
the automatic trans and case being all one unit are more compact hence a longer drive shaft.
I tried to go this way myself
what is wrong with your drive shaft??
Old Jun 2, 2012 | 08:17 AM
possum34's Avatar
Yes I figured the lengths would be different.I was hoping they were not.
My driveshaft,the u joints are wore out and it vibrates when you let of the the gas on hwy. The driveshaft from the automatic truck the joints were in great shape so i just figured swap the driveshafts out.
Old Jun 2, 2012 | 08:46 AM
Team420's Avatar
Different years, and models... but.... the drive shaft out of my 94 5spd is longer than the shaft in my 93 auto by about 1".
Old Jun 2, 2012 | 10:24 AM
85TurboRunner's Avatar
It will fit just fine, wont be exactly the same length but you will never know the difference when driving.
Old Jun 2, 2012 | 10:35 AM
waskillywabbit's Avatar
Driveshafts to function properly as balanced should be the correct length.
Measure flange to flange and check.
:wabbit2:
Old Jun 2, 2012 | 11:17 AM
jd20phill's Avatar
why don't you just replace the u-joints? will be less than 50$ and will take an hour or 2.
4x4-runner
Apr 18, 2017 09:08 PM
mussy01
Dec 13, 2016 08:20 PM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
Sr5crawler
Jul 31, 2015 12:32 PM
