just picked up a 95 tacoma with the 3rz and it has problems? need help
Old 06-17-2012, 01:19 AM
saechao503's Avatar
hi i just picked up a 95 tacoma with a 3rz motor for a really good price from one of my relatives for 500 bucks with a clean title. comes with the tow package as well. it has 195k miles orignal on it. the truck does start but when its cold you gotta give a little bit of gas though but not to much other wise itll die. and it does have an exhaust leak near the firewall area. and it runs but it has no power at all. it also has a check engine light but i havent pulled the code yet. i was just thinking of taking it to a shop and getting the motor rebuilt so ill have a fresh motor. or should i try and fix it my self? any recomendations to a shop here in gresham/portland area in oregon? im new to the trucks but i do know a little bit about cars had a civic before this it was built and turbo.. so i have some knowledge about engines. heres a picture of the truck
Old 06-17-2012, 01:20 AM
saechao503's Avatar
also its an automatic and has 4wd
Old 06-17-2012, 03:09 AM
Fossilized
Staff
dropzone's Avatar
FSM link
http://ncttora.com/fsm/index.html
Old 06-18-2012, 02:13 PM
Moonfish's Avatar
I'd check the compression. From what I know of my 3rz, if the valves don't get adjusted it will eat some. And the cracked manifold doesn't help.
Old 06-18-2012, 02:52 PM
saechao503's Avatar
It does have a check engine light havent pulled the code yet. Its leaking from the ege tube as well. Would a bad maf sensor cause it to not have power and hard to start?
Old 06-18-2012, 02:56 PM
saechao503's Avatar
Theres no tick or anything sounds just fine besides the exhaust leak
Old 06-18-2012, 03:54 PM
stepside trd's Avatar
Try these guys for your engine rebuild; nwteamyota.com, and if your on a budget, try these guys for your exhaust; toyotatruckengine.com.
Old 06-18-2012, 10:43 PM
saechao503's Avatar
its my egr tube that connects to the exhaust thats leaking i order one from toyota today. gonna check everything out this week end and pull the codes to see what it is and do a compression test on it as well
smthwsn357
05-01-2024 07:28 AM
Eggslinger
06-08-2019 03:32 PM
TokyoD23
07-12-2015 06:01 AM
akaphilly
07-09-2015 02:18 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: just picked up a 95 tacoma with the 3rz and it has problems? need help
