Sponsored by: CARiD
89 toyota pickup V6 want to lift
Old May 15, 2012 | 11:00 PM
moanamilia's Avatar
i want to lift my truck and get a straight look, its stock right now, i have pro comps tire mud terrains on 15x10's rock crawlers, i dont want a hight look but, just enought where u can tell it has a little lift, maybe like 3inch? what should i put on my truck? it would be nice to have a good ride, and also gearings? what should i change to make truck stronger so i can drive on sand?
Old May 16, 2012 | 04:39 AM
BeMiceElf's Avatar
Read through most of these. They will answer your questions.
https://www.yotatech.com/forums/f116...tickys-242840/
Old May 16, 2012 | 04:58 AM
rattlewagon's Avatar
Best thing for sand is airing your tires down, But that means youll need some way to air them back up once you hit pavement.
Read the link posted above. TONS of information in there.
Old May 16, 2012 | 05:24 AM
motocrossaddict223's Avatar
there are tons of threads out there, back probably a year ago and theres alot of info there. I have pretty much decided to go with axelike's ifs lift idea. consist of bj spacers rear ome leafs 2in body lift and 2in drive train lift. That would clear 33's and for gearing 4:88's in my opinion are perfect.
Old May 16, 2012 | 05:25 AM
forgot to add what i said above could be alot of work and is meant for if you want to wheel but dont need long travel. If you just want the look a bracket lift will be fine.
dirk89
Oct 1, 2015 05:15 PM
Brodetski
Sep 30, 2015 11:50 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
charlie_fong
Sep 27, 2015 10:06 PM
Toys4parts
Sep 26, 2015 01:56 PM
