Sponsored by: CARiD
Gasket material opinions
Old May 18, 2012 | 06:10 AM
ScHills's Avatar
In your opinion what would make the best seal on a 22re timing cover,Toyota FIPG or the type (paper felt cork etc) that comes with a timing kit.Thanks
Old May 18, 2012 | 07:04 AM
snobdds's Avatar
If both the block side and timing cover side are both properly prepped with no warpage, then the OEM paper gasket is plenty. I usually hit both surfaces with a 3m aluminum sanding puck to remove any grit. If there is some slight warpage in the timing cover, then a light coating of FIPG on the block side of the gasket is fine. Don't go crazy though.
I have seen people use FIPG sealer only with success, but that is a lot of silicone to be lying down and some could end up in your engine plugging up oil passages. Not worth the risk in my opinion.
Old May 18, 2012 | 07:59 AM
INFINITY's Avatar
normal paper gasket with cleaned surfaces and ultra grey rtv = no leaks.
dumpster84
Apr 30, 2016 06:03 AM
viesail
Aug 17, 2015 08:39 PM
Esibnitsud
Jul 30, 2015 08:19 PM
nonstop
Jul 24, 2015 06:29 PM
A2theK
Jul 12, 2015 10:46 AM
