Sponsored by: CARiD
350 vs. 3.4
Old Apr 25, 2012 | 09:07 AM
JimmyH18's Avatar
350 vs. 3.4
I'm sure this question has been beat up plenty but I havta ask it anyways. I have a 90 4runner with a 3.0 and auto transmission. I'm looking to do a swap on it and I have a 350 that I could use but I have been reading on here about the 3.4 and I just wanna weigh the pros and cons on the two. Any info would help because this will be my first swap and I would like it to be a good one. Thanks in advance.
Old Apr 26, 2012 | 02:16 AM
wyoming9's Avatar
Red face
It all comes down to what you want and your frustration level.Skill level also plays a big part .
Some things look impossible but to others it is something done without really giving it much thought.
If your doing it on a low buck budget going with the engine in hand makes sense if you know the history of the engine.
Till you source a 3.4 depending on mileage look at things and replace as needed to not have to be fixing it during the shake down cruise.
As far as the electrical end the 3.4 is going to be a lot easier and much more information being a more popular swap.
It always seems like the major things go smooth it is the lack of the right hose or wrong bolts that throws Mr. Murphy into the mix.
The words first swap could be interesting things are seldom as easy as they look.
In any case good luck
Old Apr 26, 2012 | 02:58 AM
dropzone's Avatar
Fossilized
3.4 swap folder: https://www.yotatech.com/forums/f160/
domestic swap folder https://www.yotatech.com/forums/f163/
dunno if in colorado you need to worry about having an emissions ref check your swap or not...
Old Apr 26, 2012 | 10:26 AM
JimmyH18's Avatar
No emission ref in Colorado...yet im sure that will come with time. One other question I forgot to ask was will the stock tranny hold up with a 3503 or would I also have to do so work there?
Old Apr 26, 2012 | 12:35 PM
wyoming9's Avatar
Red face
No matter what there is going to be a weak link.
Strengthen that you now have something else.
it all comes down to your use of the skinny pedal.
I thought you had all ready checked out all the swap threads here and on other forums.
Read as much as you can separate the wheat from the chaff
Old Apr 26, 2012 | 01:09 PM
bone collector's Avatar
one thing to consider is if this vehicle is gonna be your DD. if it is Gas mileage will be a big concern and the 3.4 will double the MPGs of the 350 easily.
Old May 8, 2012 | 03:10 PM
dewiseman's Avatar
Another thing to consider: Toyota guality can't be beat. Unless you are planning on pulling a BIG ASS BOAT go toyota.
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
TheBFA
Feb 15, 2020 06:55 AM
White Stripe
Oct 6, 2015 10:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
