Sponsored by: CARiD
broken speed sensor bolt heads
Old Apr 22, 2012 | 02:22 PM
cap85's Avatar
fml....i tightened the bolts on the speed sensor bracket to 14lb/ft and the heads broke off....was that because they are old? whats the best way to get them out of the differential carrier?
Old May 5, 2012 | 10:22 AM
cap85's Avatar
no hardware store or dealership has the original bolts that the speed sensor came with....they don't make those bolts with the shank on top for the size i need...so i bought a longer bolt with a long shank and cut some of the threads off and was just going to use washers where the top of the bolt is to the sensor.
should i use lock washers or just the normal washers?
thanks
Old May 5, 2012 | 10:45 AM
cap85's Avatar
i used two lock washers and two normal ones..its pretty secure. does anyone see any issues i could have with this in the future?
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
87blyota
Jul 10, 2015 04:31 AM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
