Sponsored by: CARiD
Manual transmission swap
Old Apr 27, 2012 | 08:28 AM
Cameron Kerns's Avatar
Question Manual transmission swap
I have a 1995 T100 V6 3400 is there any transmissions that could fit under my truck for a decent price? If so what trany will?
Old Apr 27, 2012 | 07:26 PM
rokblok's Avatar
I believe an R150F. That's behind V6 4runners and pickups of the '92-'95 flavor. Then again, since you have the 5VZ, I don't know if the input shaft & bell housing would be the correct dimensions. Wabbit may be able to answer since he has done several 3.4 swaps into older Runners/trucks... Call his name 3 times and wait. He will come around eventually... Or maybe someone else will chime in...
Old Apr 28, 2012 | 08:15 AM
85TurboRunner's Avatar
If you haven't already, you might wanna check the T100 section.
I figure if you can put a 3.4 in an older tuck and still run the W56 that might be an option although not a good one seeing as how the T100 is a bigger heavier truck.
Old Apr 28, 2012 | 01:38 PM
rokblok's Avatar
I thought you had to run an R tranny behind the 3.4?
Old Apr 28, 2012 | 03:03 PM
DeathCougar's Avatar
T100's came with manual transmission options. Fairly rare. A truck/4Runner transmission may not work, since they are top shift. The T100 is a forward shift case.
3.0 and 3.4 share the exact same bellhousing to block bolt pattern.
Old Apr 29, 2012 | 09:23 AM
After some looking around I think you're right. I guess I thought Advance Adapters made an adapter for the W series but I was wrong.
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
Liadrin
Sep 1, 2015 06:44 AM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
