Sponsored by: CARiD
Dry Compression/Wet Compression
Old Apr 11, 2025 | 05:03 PM
squeege's Avatar
5 Year Member
What is an acceptable difference between a dry and wet compression test that would not indicate pressure lost past rings? I have heard that 10% is normal and I have heard that there should be no difference at all if rings are ok.
Old Apr 11, 2025 | 06:03 PM
millball's Avatar
Any time you put more than a couple of CC's of oil into the combustion space, you're gonna get a change in compression numbers regardless of engine condition.
A leakdown test is a far better indicator of cylinder condition issues
Old Apr 22, 2025 | 11:52 AM
loulu3's Avatar
A 10% difference between dry and wet test is normal in many systems, especially if the rings are in good condition and there are no visible leaks.
A2theK
Apr 5, 2013 08:34 AM
taikowaza
May 7, 2008 12:58 PM
Itoyota
Mar 8, 2007 03:35 PM
L33T35T 4Runner
Jul 15, 2006 04:59 PM
Y2Krunner
9
May 27, 2003 07:35 PM
