22re compression tests
Old Jan 20, 2006 | 07:45 PM
L33T35T 4Runner's Avatar
I bought a 15 dollar compression tester at walmart tonight. It actually seems half way decent.
all 4 cylinders stopped right around 140-145 PSI.
cyl 1 - jumped up to 145 after about 3 compression strokes
cyl 2 - took about 6 or 7 compression strokes to get to 145
cyl 3 - took about 8 or 9
cyl 4 - same as 1, 3 strokes
so... whats this mean? leaking valves? leaking rings? the motor runs good. i can still smoke the tires, and shes gets up and goes faster than my 3.0l
yes, ive searched.
also, the manual that i have for a 22r-e is for a 95 4runner, but i would assume the specs would be the same?
Compression Ratio .................................. 9.3:1
Compression Pressure ............... 178 psi (12.5 kg/cm )
Minimum Compression Pressure ....... 142 psi (10.0 kg/cm )
Maximum Variation Between Cylinders .. 14 psi (1.0 kg/cm )
oh ya, i did forget to disable the EFI, if that changes anything
Old Jan 21, 2006 | 11:21 PM
no opinions?
Old Jan 22, 2006 | 05:45 AM
Yoda's Avatar
The way to do a compression test:
Engine warm
Remove all sparkplugs
Throttle held wide open (air has to get into cyl's to compress)
I generally count 6 cranks and then read gauge
If any are low, repeat with a little oil added to each cyl (to help seal rings), if good then, it is a ring prob. If still not good, it is a valve or head gasket problem
I don't think you have much of a problem (if any) with your readings.
Old Jul 15, 2006 | 09:42 AM
rdharper's Avatar
Compression test... fuel injectors
Engine warm
On a 22re, would it not make sense to disconnect the battery as well? It seems to me that assures no fuel injected into the cyclinder which might confuse the result, not to mention you will avoid the loose ignition wires from looking for something to short to, like your fingers...
I'm going to try it on my '85, just to make sure I can get good readings while the truck is working well. Comments are welcome.
Old Jul 15, 2006 | 11:59 AM
rdharper's Avatar
Uhhh... Harper? How are you going to crank the engine to do the compression test if you disconnect the battery?
Old Jul 15, 2006 | 04:59 PM
he may have been thinking about a leakdown test
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
RatOmeter
Oct 22, 2015 03:17 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
