Sponsored by: CARiD
stubborn bolt
Old May 30, 2010 | 04:33 PM
kdogy313's Avatar
stubborn bolt
what are some good ways to get a stubborn bolt out? i have tried hitting it, i hhave used pb blaster and still have no luck. the bolt is on the lower a-arm. i am putting a pro comp susp. lift on and this is the only thing holding me back
Old May 30, 2010 | 04:47 PM
betelnut's Avatar
1/2" breaker bar, with cheater bar if needed.
Old May 30, 2010 | 05:02 PM
xxxtreme22r's Avatar
sounds crazy, but.... try tightening it first, but not too much then loosen it up, also try a propane torch and heat it up a bit.
if that doesn't work get you some of these :
Old May 30, 2010 | 05:23 PM
kdogy313's Avatar
the nut is already off. if i used a torch wouldn't the pb blaster ignite? it seems like its stuuck in the rubber gromet thing. i used the 1/2 in breaker bar and i used a jack to jack up the handle but it didnt do anything. what about cutting the bolt?
Old May 30, 2010 | 05:26 PM
have you tried adding some pressure on the arm with the jack? I am assuming you are on jack stands now. Thank you for letting us know you already had the nut off. As neither of us thought you did.
Old May 30, 2010 | 05:49 PM
kdogy313's Avatar
yes i have tried adding pressure. im not on jack stands..... because i have none, but i have it up on up on my floor jack. and i have the stock toyota jack and another floor jack. i just needd to get this nut off and the lift should be done within an hour and a half.
Old May 30, 2010 | 05:53 PM
yotaman85's Avatar
if its that stuck just cut it off..
Old May 30, 2010 | 05:56 PM
kdogy313's Avatar
thats what i was thinking. i just need to go borrow a sawzall. i have a donor truck so i have plenty of spare bolts.
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
