Sponsored by: CARiD
Coolant Exploded, now car overheats badly?
Old May 17, 2010 | 08:14 PM
westonian18's Avatar
Was driving on a fairly long roadtrip, engine coolant reservoir cap explodes off and coolant goes everywhere. I filled the radiator back up, got back fine but just tonight I drove her back from a friends place and its sizziling and gurgling with the temp gauge in the red.
Im thinking possible bad water pump, any ideas?
Old May 18, 2010 | 11:39 AM
snoweater's Avatar
i'm not sure if that's the head gasket problem or not (MANY threads about it) but DEF. DO NOT LET IT OVERHEAT anymore than it has. If you have a 3.0 v6 (i'm guessing) you'll warp the aluminum heads if you haven't already.
Look in your reservoir and see if it is overly dirty or black'ish looking. If so, you're HG went and you're leaking oil into your coolant.
Did you fill the reservoir to the "full" line or all the way to the top?
p.s. anytime you're asking for advice, mention what you are driving and what engine it has. or you could put your vehicle specs in your signature like many ppl do.
Old May 18, 2010 | 12:38 PM
UKMyers's Avatar
Your cap did not just blow off and your radiator spew out all of it's fluid because it was bored. Something caused it happen. Filling it back up is not going to fix the original issue. I've never seen a water pump fail without a leak to follow it. Do you have any leaks? Do you have steam coming out of your tailpipe? If you have a 3.0 I'm afraid you may have joined the blown headgasket club.
Old May 18, 2010 | 12:43 PM
Elton's Avatar
judging by his profile pic he has a 3.0L im sorry man it just got expensive
Old May 18, 2010 | 01:56 PM
brian2sun's Avatar
It could be the thermostat is stuck closed. A head gasket wouldn't be anything out of the ordinary for the 3.0, but it can't hurt to hope for something easy.
Old May 18, 2010 | 08:42 PM
Thanks guys, its a 3slow 1993 4runner auto, and there are minor oil leaks to add to the equation.
Old May 18, 2010 | 11:14 PM
wyoming9's Avatar
Red face
Curious did heat up over a long time as you watched the temp gauge climb or happen all of a sudden.
Had you checked the coolant level in the last couple of days before this.
I can`t think anyone would drive a overheated vehicle except for combat damage in a ambush.
Do you have a pressure tester to check the cooling system??
Old May 19, 2010 | 08:38 PM
thefallman's Avatar
i have seen water pumps fail to pump with out leaks. it was a completely eroded fins on the pump.
the1998sr5
15
Jul 14, 2020 08:35 PM
WellsR
12
Jul 31, 2015 03:27 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
