Sponsored by: CARiD
can i swap transfer cases?
Old Jun 1, 2010 | 11:05 PM
KODE's Avatar
i got a 90 4runner with a g58 trans and a forward shift chain driven transfer case. i wanted to know if i can swap my forward shift chain driven transfer case for a 4cyl gear driven top shift transfer case.
can i do this with no modifications? i have an extra 4cyl top shift t-case in my garage. i want to run a twin stick and eventually run duals.
Old Jun 2, 2010 | 05:54 AM
tc's Avatar
tc
When you say "no modifications", what's the limit?
I don't know if they have the same bolt pattern to attach to the tranny, but I do know the shifter will be 4-6" back, and will not come through the floor in the right place. A dogleg shifter can take care of the boot issue, but you will likely need a new hole in the floor.
Old Jun 2, 2010 | 09:38 AM
KODE's Avatar
by no modifications, i meant if it will bolt right up. i dont mind cutting a new hole in the floor. my transfer case is a chain drive forward shift and i want to be able to add a dual case or a twin stick.
Old Jun 4, 2010 | 01:00 AM
KODE's Avatar
so can i use a twin stick with my transfercase?
Old Jul 29, 2010 | 07:02 AM
tiresmokindad's Avatar
Originally Posted by KODE
i got a 90 4runner with a g58 trans and a forward shift chain driven transfer cases. i wanted to know if i can swap my forward shift chain driven transfer case for a 4cyl gear driven top shift transfer case.
Technically you could but the mods needed to be done may compromise the entegrity of that link in the chain have you tried a salvage yard yet?
SMOD
Jul 23, 2015 10:29 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
