Sponsored by: CARiD
engine is running really weird
Old May 31, 2010 | 09:13 AM
machine23's Avatar
hey guys
1994 4runner 3vze m/t 250k mi
i just got done fixing a water leak where my timing belt idler pulley meets my lower intake manifold. it involved removing the timing belt and the #1idler pulley. after i fixed the leak i put everything back together. i put the crank to 0 degrees tdc, lined the cams up with their timing marks, and made sure the #1 cyl was at tdc by using a small rod and watching it reach the highest point in the cylinder while i turned the crank by hand. so everything should have been fine. after i put everything together i got the engine running. it seemed ok until it got warmed up. then the exhaust started making popping sounds. and there is no power. the engine vibrates a lot too. and i redid the timing with a timing light. still no cure
Old May 31, 2010 | 03:09 PM
yayfortrees's Avatar
How positive are you that the cylinder was at TDC *COMPRESSION*? There's TDC overlap, and TDC compression. The valves will be closed when it's at TDC compression (TDCC).
Old Jun 1, 2010 | 08:21 AM
machine23's Avatar
im positive it was at tdc..
Old Jun 1, 2010 | 11:15 AM
Sal's Avatar
Sal
Sounds like the firing order might be messed up. Did you pull the distributor? or the plug wires while working on it?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
