Sponsored by: CARiD
Which Transmission Do I Have?
Old May 23, 2010 | 09:36 PM
90toyo4runner's Avatar
I have a 1990 toyota 4runner v6 3.o 5spd and im replacing the shift lever bushing and shift lever ball seat not sure which ones to get. Can someone look at the links and tell me which color to get? thanks
Old May 23, 2010 | 09:43 PM
PismoJoe's Avatar
Most likely the R150F, F is 4wd, R150 is 2wd
Old May 23, 2010 | 09:44 PM
ya its a 4x4 and heres the links, i forgot to post them.
http://www.marlincrawler.com/transmi...ver-ball-seats
http://www.marlincrawler.com/transmi...t-lever-socket
Old May 23, 2010 | 09:53 PM
norcal707's Avatar
ok.....i have a question. why are you replacing this parts?....
Old May 23, 2010 | 10:23 PM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
Most likely the shifter is sloppy. These parts help correct that "loose" wobbly feeling after the bushing and bowl break apart over time. That in turn leads to popping out of gear and so forth.
Old May 23, 2010 | 10:32 PM
yea its a little sloppy, i went to a tranny shop to get some tranny fluid and he checked it for me by putting the shifter in nuetral and lifting up on it, and he said it was worn(too much play) and with the price you might as well change them. did you check the links to see which ones?
Old May 23, 2010 | 10:40 PM
any looked at the links?sorry im trying to order them tonight, wont have time tomorrow
Old May 23, 2010 | 11:16 PM
flyingbrass's Avatar
If your transmission is original, look at the plate on the firewall to find the model.
Old May 23, 2010 | 11:19 PM
toyota4x4907's Avatar
actually in a '90, it would be on the driver's door jamb
Old May 23, 2010 | 11:41 PM
My 86 has a plate on the door jamb. It has the VIN and other info (month and year of manufacture, tire size and pressures, etc.), but not the color, trim, axle and tranny numbers. Those are only on the firewall plate.
Old May 24, 2010 | 12:18 AM
adamsbro1's Avatar
Order the white one
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
