Sponsored by: CARiD
Will not idle
Old May 26, 2010 | 08:14 AM
redstang's Avatar
Will not idle
I have a 1987 toyota pick up with 22r eng. It will not idle. I first started by rebuilding my carb twice, still wont idle. bought whole new carb and installed and repplaced all vacume lines. still will not idle. if accelerate it runs great has great power thru all the gears. could this be some sort of elect problem? please help!
Old May 26, 2010 | 08:33 AM
toyospearo's Avatar
I had the same problem. I rerouted the negative wire from the fuel cutoff solenoid on the carb to the negative terminal on the battery. Mine runs flawlessly now. Not one stall in two tanks of gas!
Old Jun 1, 2010 | 03:59 PM
thebrick's Avatar
I had a similar problem after i fried some wires off the positive battery terminal. After i rewired the terminal and the wiring to the idle solenoid thingy that got fried as well it worked fine.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
