Sponsored by: CARiD
overheating still!
Old May 14, 2010 | 09:19 AM
mr.spohn's Avatar
overheating still!
hi i posted about a week or so ago about my 1997 4runner overheating. I have sence replaced the water pump another new thermostat. and still the same problem. i am at a total loss. head gaskets done about 100 miles ago. i am ready to junk the engine.
Old May 14, 2010 | 09:48 AM
Jay351's Avatar
What else have you done? Are you sure you got all of the air out of the cooling system? You burped it right?
Old May 14, 2010 | 09:55 AM
brian2sun's Avatar
Sounds like you have a blockage somewhere either in the cooling passages in the engine or the radiator itself. I would stick a garden hose in both and find out which one's clogged. Who did the HG work?
Old May 14, 2010 | 10:00 AM
snobdds's Avatar
My bet is on a air bubble in the cooling system. Somtimes they are so hard to get out and will make your rig overheat.
Old May 14, 2010 | 10:58 AM
swampfox's Avatar
have you checked the radiator hoses to see if one might be collapsing ? it good cause restricted water flow. i haven't seen a toyota do it but there is always a first time for everything.
Old May 21, 2010 | 08:03 AM
joshoowaray89's Avatar
well trusted mechanic do ur headgasket?? ive worked at a toyota stealer and seen some crazy stuff wid people thinkn they can fix there own stuff..ive seen headgaskets put on backwards blocking coolant flow and all..but yea just check make sure all the air is worked out the coolant system
Old May 21, 2010 | 09:17 AM
snobdds's Avatar
see if your radiator cap is good. an easy fix usually over looked.
Old May 21, 2010 | 11:34 AM
DoveGray85's Avatar
Maybe you have a clogged radiator. Have it checked at a radiator shop or just replace it.
ladybugRC
458
Aug 21, 2020 10:41 AM
Corvoid
Dec 11, 2015 11:21 AM
alexcarey
Oct 14, 2015 06:05 PM
larrys93pickup
Sep 17, 2015 07:05 PM
LotOMiles
Sep 14, 2015 11:45 PM
