Sponsored by: CARiD
tps position affect idle at 2k rpm?
Old May 14, 2010 | 07:54 PM
gweelie's Avatar
So I've been struggling with my 4runner's idle lately, it was idling at 1500 rpms and after much deliberation as to whether or not the tps was bad, I decided to pull of the throttle body, check the tps and give the tb a good cleaning. The tps ended up being ok and the tb was pretty dirty, but nothing to bad. I re-assembled everything and the idle was still around 1500 rpms. I tilted the tps upward a tad, and the idle dropped to 1000 rpms, but when a would press the gas, at 2k rpms, the truck would jump between 2k and 1500rpms. So that was a long way of asking if tilting the tps could cause that affect? I intend on returning the tps to the original location, but I need more ideas as what to do to correct my high idle. Thanks
Old May 14, 2010 | 09:19 PM
4Crawler's Avatar
How are you setting the TPS idle position?
The proper way is described below:
- http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment
Old May 14, 2010 | 09:21 PM
dark_fairytales's Avatar
yes you need to adjust tps back to spec.
you first issue could have been caused from a few different things suck as vacuum leak and or exhaust leak.
Old May 15, 2010 | 08:20 AM
gweelie's Avatar
I realize it may be a long shot, but the muffler has some holes in it, could that be an issue?
Old May 15, 2010 | 12:23 PM
that is one of the longest shots i have heard in a vary long time.
start with the tps and go from there.
Old May 15, 2010 | 06:00 PM
gweelie's Avatar
Thanks, I pride myself on the long shot.
Old May 16, 2010 | 05:31 PM
gweelie's Avatar
So I went back under the hood to adjust my tps... and I'm not getting a reading between the e2 and idl terminals. At the lowest ohm setting on my multimeter, 200, it flashed something really low (can't seem to remember right now) and @ 2k and 20K no reading... so I assume I screwed up originally and tested it wrong. my new question is, would a bad tps throw a check engine light, or just go out with only an idle problem to indicate? I don't want to spend $100 on this part and not have it help, I'm unsure as what to do. Any helpl on the c.e.l. question is greatly appreciated.
Old May 16, 2010 | 06:31 PM
1welder's Avatar
you could check your Idle Air Control valve also. i think if it is stuck open it will cause a high idle. vacuum leaks cause high idles. i think the tps will give you cel only if it goes completely out.
Old May 16, 2010 | 06:48 PM
SoCal4Running's Avatar
Local here, not sure if I can help.
Old May 16, 2010 | 07:02 PM
1welder's Avatar
what motor do you have?
Old May 16, 2010 | 07:20 PM
gweelie's Avatar
v6 3vz-e
Old May 16, 2010 | 07:22 PM
gweelie's Avatar
it does appear to ONLY not give the readings between e2 and idl.... is it possible to partially malfunction and not throw a c.e.l.?
Old May 16, 2010 | 07:28 PM
4Crawler's Avatar
I think that the ECU only detects a short on the EDL-E2 circuit, but not 100% sure on that. All that signal tells the ECU is that the throttle is closed (at idle) and if that contact never closes, as far as the ECU is concerned, the throttle has not been closed. So it might be the TPS IDL-E2 contact strip is bad or just that the idle position has not been properly adjusted.
Old May 16, 2010 | 08:01 PM
gweelie's Avatar
unless I'm reading everything wrong, don't you need the idl-e2 terminals to properly adjust?
I did the allen head screw replacement that was suggested, so I can go in and try every position under the sun, I think I'm gonna buy the damn sensor and hope it works out for me.
Old May 17, 2010 | 04:48 PM
gweelie's Avatar
bought a new tps, dropped the idle some, (1250) probably not adjusted right, but the truck smells really bad (exhaust). It never smelt great, but it is potent now. I'm sure I'll have to replace the cat amongst other items to smog it. I've come to realize that I'm dense and can't seem to follow directions on how to properly adjust the tps, I'm counting on my brothers help tomorrow to get it done right, fingers crossed.
Firefightersink15
Nov 23, 2015 10:32 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
creecher10
Sep 30, 2015 03:27 PM
Ricu_air
Sep 21, 2015 08:09 AM
