Sponsored by: CARiD
Stock Torsion bar setting
Old Jun 7, 2010 | 09:38 AM
rfcruse's Avatar
I just bought a new 4runner (86) which has the torsion bars cranked way up. I want to return the truck to stock ride height.
I'm assuming I can just un-crank the t-bars, right? How can you tell when you've reached stock ride height?
Thanks
Old Jun 8, 2010 | 09:23 AM
rfcruse's Avatar
Do I need to jack the vehicle up and remove the wheels to unload the t-bars if I am simply lowering the vehicle, effecitively un-cranking them? Can I do this with the truck on the ground?
Old Jun 8, 2010 | 09:29 AM
MaK92-4RnR's Avatar
Measure the edge of your fender to the edge of your rim. stock should be 15" from rim to fender.
http://www.4x4wire.com/toyota/tech/torsion_bars/
Old Jun 8, 2010 | 09:34 AM
Teuf's Avatar
Yup do this on flat ground, adjust, bounce it up and down a couple of times, remeasure, go around block, remeasure again.
Old Jun 13, 2010 | 01:36 PM
89 black toy's Avatar
how do you crank the t bars down? my truck has them way up and im wanting it stock to lift it 2 inches i want it to sit level thanks for any help.
Old Jun 13, 2010 | 01:45 PM
Teuf's Avatar
Adjust counter clock wise, that will raise the upper arm, in affect lowering vehicle.
Old Jun 13, 2010 | 04:04 PM
xxxtreme22r's Avatar
not that mine is set right (front end has been rebuilt by P.O. after crash), but on my 87 pickup I have 13 1/2 " from a 15" rim to fender.
that 15" he shows there looks like it's on an 89-95 pickup.
Old Jun 19, 2010 | 06:35 AM
95blackToy's Avatar
you do have to jack it up. use a floor jack and jack the whole front end, then you can start uncranking the bars.
Old Jun 19, 2010 | 06:40 AM
az4x4runner's Avatar
Yes, jack it up. You may want a spare set of adjuster nuts & bolts. Depending on where you live especially (rust) they may be almost impossible to turn. I live in AZ and have pretty much no rust on my 4runner and they are still seized solid. I am counting on having to replace them if I need to adjust/snap them.
88sasturbotoy
Jan 30, 2026 01:57 PM
80Truck
Oct 12, 2025 07:25 PM
RatOmeter
Oct 22, 2015 03:17 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
