Sponsored by: CARiD
rear axle help: how to determine gear ratio
Old May 12, 2010 | 05:04 PM
yota_krawler's Avatar
i just got a rear axle off craigslist for $300 and i am wanting to find out the gear ratio. he said it has 5.71s in it but i want to double check. I do i go about doing this?
Old May 12, 2010 | 05:24 PM
camo31_10.50's Avatar
you can...
A. take out the pumkin, count the teeth and do the math and figure it out that way.
B. do the driveline (or in your case, flange) rotations, and count the number of rotations the axleshaft makes, and then do the math and get it that way
Old May 12, 2010 | 05:59 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Here, I'll tell you.
http://home.4x4wire.com/erik/diffs/#ratios
Old May 12, 2010 | 06:07 PM
ok thanks, i will pull the pumpkin out. when pulling it out, do you have to pull the axles out or just take the nuts off the pumpkin and it will come out?
Old May 12, 2010 | 06:08 PM
dropzone's Avatar
Fossilized
pull the axles all the way out,
do not allow the axles to rest on the axle seals, you may end up with leaks down the road
Old May 12, 2010 | 06:11 PM
oh, hey, and another thing... Is there a mark of paint on the pinion?
http://www.4crawler.com/4x4/4R_TechI...#Differentials
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
