Sponsored by: CARiD
Is 4" to much lift
Old Jun 2, 2010 | 03:36 PM
coronadrinker85's Avatar
Is 4" to much lift
Is 4" to much lift to be using off roading? I keep reading that lift is for the mall parking lot and lockers and gears are for the trails. My main concern is to be too top heavy
Old Jun 2, 2010 | 03:38 PM
rebelrunner's Avatar
depeneds on what type of wheeling your going to be doing.
Old Jun 2, 2010 | 03:39 PM
rattlewagon's Avatar
Depends on the lift and what you plan to do with it. We need a little more info here. What type of off roading do you do?
Old Jun 2, 2010 | 03:40 PM
shawns88's Avatar
its up to you what you want to do, 4 inch lift gets you the right to put bigger tires on it witch = more ground clearence. but if you get lockers you wont have to worry about doing one tire fire =) or if you get both you will have one bad ass rig =)
well I'm new to off roading, but i really like going on trails. i probably wont be doing much mudding or rock crawling.
Old Jun 2, 2010 | 03:42 PM
toyota4x4907's Avatar
Then do you even need a lift?
Spend that money on some armor.
Old Jun 2, 2010 | 03:44 PM
^x2 if your gonna do trails buy some lockers and armor.
Old Jun 2, 2010 | 03:47 PM
yoder519's Avatar
my 95 yota is lifted 4in- 2in body 2in susp, 35s. i think its the perfect stance. i kno i kno do you need this lift yada yada. but i think most of us can admit, we lifted our truck/runner for looks and function. cuz admit, a lifted yota looks dern skippy, i lifted mine fro looks in the beginning.
Old Jun 2, 2010 | 03:48 PM
the only reason i was thinking about a lift is beacuse the last time i went off roading i hit my frame on a bolder once the front wheel went over it.
I was one click away fron buying this http://store.fatbobsgarage.com/toyot...995-p5682.aspx when i found a 4" pro comp kit for $200
Old Jun 2, 2010 | 04:07 PM
MB4runner's Avatar
Whoever said lifts are for the mall is misinformed. HUGE lifts are for the mall, but a nice 4" lift will have plenty of benefits for offroad use. Better clearance, approach, departure angles etc. You won't bottom out on the frame rails as easily. Room for bigger tires etc.
Old Jun 2, 2010 | 04:19 PM
craneguy001's Avatar
you need more like a 10in lift dont be scared you want your ride to be able to do somethin not be sittin on the side watchin all the big rigs go by because you got a little lift. have fun
Old Jun 2, 2010 | 04:24 PM
LOL i saw your thread craneguy, your truck is nuts! unfortunately my truck is IFS and my DD
Old Jun 2, 2010 | 04:33 PM
right on corona man my rig usted to be ifs but i wanted a real toy thats still a dd but them my other ride is a blown 560hp 02 mustang thats a dd to. I always thought go BIG to begin with and you wont be sorry you didnt later..
Old Jun 2, 2010 | 04:37 PM
Good word to live by! LOL
Old Jun 2, 2010 | 04:42 PM
I try and tell people that.. some listen and and are happy, some laugh and are miserable with themselves.. LMAO but the reality of it is, what you can afford and fab/do by yourself and not have to pay someone to do because thats usually half the cost. Have fun with your build and put some pics up
Old Jun 2, 2010 | 05:05 PM
xxxtreme22r's Avatar
full belly skid plate would be good for these kinda problems. And maybe an IFS trus.
Old Jun 2, 2010 | 05:17 PM
xxx is right that will save alot of tearin stuff up on the underside of your ride. That would be one of those easy starter things to do on your own that you cant mess up if you up to the challange. just dont weld up the wrong thing and measure twice cut once or youll waste alot of material
Old Jun 2, 2010 | 05:56 PM
Swimmerboy2112's Avatar
This is a good thread as i was also considering a 4" Rough Country lift. Maybe i'll just invest in some armor first...
Old Jun 2, 2010 | 06:26 PM
Ron's 85's Avatar
pro comp is cheap for a reason. i had a pro comp lift on my runner, it had no flex, it was all MALL. i recommend spending your money on a nice set of tires, trim some fender and build some armor.
Old Jun 2, 2010 | 06:31 PM
thanks for the input rons85, i really dont know much about pro comp. i think im going to get the 2" kit i posted the link to and an aussie. 2" should work/look good with my 33's
