Sponsored by: CARiD
have questions on new gauges
Old Jun 1, 2010 | 09:39 PM
Brian Pearson's Avatar
i just got a good deal on a set of gauges from my local parts store. anyway i need to know where on the block to thread in the oil pressure, water temp and how to wire the amperage.. thanks.. its a 91 toyota 3.0 5speed 4x4
Old Jun 1, 2010 | 10:27 PM
DeathCougar's Avatar
Read the instructions?
Or google "How to wire ammeter" and "how to install oil pressure gauge" and "water temp gauge install"
Old Jun 2, 2010 | 05:03 PM
first of all i read the directions and since they are universal gauges there is no answer to where to hook them up. also i checked google . i know someone that has a 3vze can tell me the exact locations to route the lines ect.
Old Jun 2, 2010 | 06:18 PM
RobD's Avatar
Oil pressure sending unit will require a British Standard Pipe Thread adapter, since your gauge kit likely came with a 1/8" NPT fitting.
http://www.autometer.com/cat_accesso...il.aspx?vid=59
The sending unit is right near the oil filter on your 3.0. Looks like a little can with a wire coming off of it.
Installing the temp sender gives you a couple options. You can try to find one of your stock sending units and replace it, but I went with a top rad hose adapter from Autometer, as well.
http://www.autometer.com/cat_accesso...il.aspx?vid=51
Old Jun 2, 2010 | 09:33 PM
thanks for the reply Rob. that will help
Old Jun 2, 2010 | 09:48 PM
RobD's Avatar
Oh, forgot to mention, but you'll have to remove the existing sending unit and use the one that came with your gauge kit, but I assume you already know that.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
Nickyodaman
Jul 27, 2015 12:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
