Sponsored by: CARiD
pinging on freeway up hill?: spark plug issue?
Old May 24, 2010 | 04:24 PM
shafner30's Avatar
hello
i am having a pinging thing going on...
when i am going up hill on freeway it starts to ping....egr is clear...
i am running
nkgs gp platinum plugs
do you guys think the plugs are making the engine ping ?
anyone else have a any trouble with those plugs?
let me know
thanks
Old May 24, 2010 | 05:58 PM
shafner30's Avatar
whats spark plug to use?
hello
what ngk spark plug should i use on a 22re
the ngk gp platinums spark plug i got on now i think they are causing pinging at highway speeds egr ok...
let me know thanks
Old May 24, 2010 | 06:01 PM
BigBluePile's Avatar
try a higher octane?
Old May 24, 2010 | 06:06 PM
shafner30's Avatar
i tried that
Old May 24, 2010 | 06:07 PM
PismoJoe's Avatar
x2 but also here are the correct plugs
ND W16EXR-U
NGK BPR5EY
Old May 25, 2010 | 09:15 AM
yayfortrees's Avatar
It would help if we knew what motor you're talking about. If it's a 22R(E), check the cam chain guides. If it's broke, it will allow the timing chain a little more slack, which can change your cam timing. If the cam is a little out of time, than so is your ignition timing, and that can cause some pinging.
My truck used to do this with the old motor. When it finally went, I found the chain guide in about 4 or 5 pieces, and I think that was the main contributor to the pinging.
It can also be caused by excessive compression, which is quite rare. This requires a lot of carbon build up to achieve too much compression on accident. Also, any high spots inside the combustion chamber can act like glow plugs, causing pre-ignition detonation, which is similar. High spots can be caused by carbon deposits, or metal tabs, like a metal filing. Again, the likelyhood of this being the problem is very low.
If the motor is the 3.0, I don't know what to recommend besides checking the ignition timing.
Good luck and keep us posted.
Old May 25, 2010 | 09:42 AM
PismoJoe's Avatar
he said its a 22R-E
Old May 26, 2010 | 08:46 AM
PismoJoe's Avatar
FYI for spark plug questions, check this out: http://www.globaldenso.com/cgi-bin/g...&action=search
Old May 26, 2010 | 01:44 PM
Whoa, that's weird. I could of sworn when I typed my reply, there was only the original post.
Well, if the spark plugs don't get rid of the pinging, make sure to check ignition timing, and if necessary, check compression.
Old May 27, 2010 | 06:28 AM
myyota's Avatar
Run a little seafoam through the engine to clean out any carbon build up that might be in the cylinders, and see if that helps.
Old Jun 9, 2010 | 11:17 PM
Ron Helmuth's Avatar
fouled air and fuel filter was causing this in Oregon when I was back there a few years back with my 95 Runner with 22Re.
mad props to the Yota dealership in The Dalles Oregon for figuring it out and getting me back to running fine. We poured several bottles of Techron fuel system cleaner through it as well and they suggested I had picked up a bad load of gas along the way also.
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
