Sponsored by: CARiD
Transmission Trouble: '85 manual
Old May 17, 2010 | 07:04 PM
adventuremachine's Avatar
I have an 85 pickup with a manual transmission and it will not shift into reverse or 5th gear. I have replaced the seat and bushing on the shifter which I found to be broken. This made no difference with the shifting problem. Any suggestions or insights would be greatly appreciated.
Old May 28, 2010 | 07:35 PM
hellion's Avatar
try swapping in a new clutchplate. I have an 85 yota pickup and when it atarts doin that to me i change the clutch and it usually fixes it
Old May 29, 2010 | 02:03 AM
85TurboRunner's Avatar
could be the syncros how many miles on the tranny. They eventually wear out.
Old May 29, 2010 | 02:42 PM
hellion's Avatar
true but it honestly could be a whole bunch of different things such as shifting forks, the gears could be completely shaved which is a worst case scenario but it wouldnt hurt to check them, and as well as the syncros i just said clutch because thats one of the cheaper things in the trans
Old Mar 27, 2011 | 04:35 PM
Jmitchell5's Avatar
Does anyone kno what transmission is in an 85 toy pick up sr5 5 spd manual
Old Mar 27, 2011 | 04:46 PM
streetlancer's Avatar
If it's carburated G52
EFi W56A
But anything from 1984 to 1995 behind a 22r will work, theres just small differences such as forward shift vs top shift. Worst case scenario you will have to trim the cab floor for the new shifter position I did it went from a G52 tranny to the stronger W56b. This has been asked countless times do a search next time there's infinite info in here....
Old Mar 27, 2011 | 04:48 PM
Jmitchell5's Avatar
Ok ty I searched on here but didn't see anything that had year specific but thanks for the years that will work that's helpful
Liadrin
Apr 25, 2022 02:54 PM
4x4-runner
Apr 18, 2017 09:08 PM
Liadrin
Sep 1, 2015 06:44 AM
Dennisx2
Aug 4, 2015 01:26 PM
Poncho0206
Jul 10, 2015 06:21 PM
