Sponsored by: CARiD
3VZE head gasket
Old Feb 29, 2012 | 05:30 PM
jpierce460's Avatar
3VZE head gasket
can any body tell me if I can put my haeds on without taking my cams out, I got two new heads and they came complete with cams already installed, and don't want to take them out so can any body give me some good advice on it. PLEASE HELP
Old Feb 29, 2012 | 05:35 PM
rworegon's Avatar
Can't do it. See FSM in signature line.
Oh, well I'll post the link:
http://www.ncttora.com/fsm/1990-1995...e/cylinder.pdf
Old Feb 29, 2012 | 06:27 PM
BMcEL's Avatar
Holy big text batman.
Old Mar 1, 2012 | 04:43 AM
jpierce460's Avatar
not what I wanted to here but thx you very much for the link a lot of good imfo. what do you think about head bolts or the studs?
Old Mar 1, 2012 | 05:49 AM
MudHippy's Avatar
The stock head bolts are more than sufficient.
I don't know of anyone that's actually used studs on this engine. So not only are they a ridiculously expensive option, there's no real evidence/proof that they work any better than the bolts.
Old Mar 1, 2012 | 06:42 AM
Sperry's Avatar
On my 3vze, I did remove both heads with the cams installed. But, there are a few head bolts that cannot be completely removed (or installed) with the cam in place. I did not want to mess around with the cams or shims. Eventually, I decided to remove the cams so I could retool the heads and install new head bolts. Before removing, I just marked each cap with an arrow for direction. I marked the bucket lifters and removed each one as well.
One thing,....when your cam is out, unless you remove the bucket lifters, do not turn upside down.
When I went to put it all back together, I just put each piece in the identical location and torqued to spec. It was pretty easy and strait forward. Been running fine ever since.
Old Mar 1, 2012 | 10:55 AM
Jasper 83's Avatar
Im glad thats yall workin on those 3.slo's and not me. Id rather slam my head repeatedly in a car door than put two new heads on that thing. Helped my buddy do his about 8 months ago. What a PITA.
I will give you some advice though. Thoroughly check that you are putting those head gaskets on the right side. If not youll block a coolant port and be doin it again
Old Mar 2, 2012 | 03:36 AM
jpierce460's Avatar
thanks for the advice everybody just waiting for the gasket set to get here and then I can start putting it back together going to have some fun with it ye ha!!!!
Old Mar 2, 2012 | 09:31 AM
jpierce460's Avatar
I have another ? I lost my oil pressure about 2years ago when I started up the truck I had oil pressure until the truck warmed up and the pressure would go down to 0 but never started knocken or getting Hot nothen should I just go ahead and get a new oil pump to be safe or what?
Old Mar 2, 2012 | 03:20 PM
Sperry's Avatar
Tough call.... maybe check your oil sensor..but I wouldn't fool around with low oil pressure.
Old Mar 2, 2012 | 08:22 PM
jpierce460's Avatar
who nows what year toyota stoped making soild axels?
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
