Sponsored by: CARiD
My diagnosis port cap is missing
Old Apr 10, 2012 | 04:29 PM
Weib Macht's Avatar
I need to pull a flash code, but I don't know which terminals are t1 & e1. I saw a diagram around here some where. hope some one can help.
Old Apr 10, 2012 | 04:47 PM
rworegon's Avatar
What year and engine? Mind readers, we are not.
Old Apr 10, 2012 | 04:52 PM
xxxtreme22r's Avatar
http://www.4crawler.com/4x4/CheapTri...CheckConnector
don't match?
Download your FSM here, I am sure it will show you as well: http://www.ncttora.com/fsm/index.html
Old Apr 10, 2012 | 05:52 PM
Weib Macht's Avatar
94' 3.0. sorry. I presumed that the t1 e1 thing was unique to the '91-'95 3.0 (or whatever the years are)
Old Apr 10, 2012 | 05:53 PM
Weib Macht's Avatar
don't match?
you sir, are the man. Exactley what I needed. I will be back with a code shortly!
Old Apr 10, 2012 | 06:08 PM
Weib Macht's Avatar
code 17? also horrible mileage
Old Apr 10, 2012 | 06:16 PM
MudHippy's Avatar
There's no code 17. Do you mean 71?
Old Apr 10, 2012 | 06:21 PM
Weib Macht's Avatar
must be. Sorry. I did some searchin, and think that I have a few leads. Thanks for helpn' a newb.
Old May 7, 2012 | 05:30 PM
Weib Macht's Avatar
just wanted to post up in case it helps someone. When I put the engine in my runner, the weak a$$ engine hook on the passenger side bent inwards, towards the egr valve. I had trouble plugging the vacuum line back in 'cause the hook was in the way. At some point, the little "nipple" on the egr got bent enough to create a hairline crack at it's base on the egr. I used some jb weld I had to seal the crack. The best fix? I guess not. Did it work? Hells yeah! I got about 2g into this runner with about 128,000 miles. It's suuuuuper clean, and even has the optional rear seat. I could prolly get at least 4g for it in my neck of the woods. Maybe 4.5g. Is it fast? nope! Get good mileage? Heeeeeellls no! Does the wife like it? Yeeeeeep. I like the newer yota trucks. This one, not too impressed. It'll do for now. (I'm actually more of a blue oval guy, converted from a bow tie guy.)
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
dumpster84
Apr 30, 2016 06:03 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Iceman4193
Aug 28, 2015 08:43 PM
