Sponsored by: CARiD
No power to fuel pump.
Old Mar 10, 2012 | 04:40 PM
Daltonroberts83's Avatar
Exclamation No power to fuel pump.
Fuel pump stopped working so i replaced it today with a new bosch. Much to my surprise there is still no power. I checked the EFI and COR relays and they are fine.
Old Mar 10, 2012 | 04:54 PM
Bigblock's Avatar
What are we working on here?
Old Mar 10, 2012 | 05:08 PM
"97 4runner SR5 4x4
Old Mar 10, 2012 | 05:27 PM
97 4runner sr5 v6
Old Mar 10, 2012 | 06:11 PM
Inferno451's Avatar
I know it's a totally different beast, but on my 22re the fuel pump ONLY gets power if the engine is already turning (even if only by the starter). As i understand it, it's a safety mechanism; if you crash and your engine is dead, you don't want fuel still pumping. I don't know if your engine has something like that, but you might check it out.
Old Mar 10, 2012 | 07:19 PM
jammin962's Avatar
Have you checked for 12v at the pump? I know that on the 3vze the fuel pump power goes through the vafm.
Old Mar 11, 2012 | 08:19 AM
i was told to check the ground wire to the fuel pump. Does anyone know where that is located?
"97 Sr5 4run
Old May 11, 2015 | 08:33 AM
skymonkey's Avatar
Having same issue on a '98 4runner SR5 V-6. everything checks good but 0vdc at the pump connector. Did you get a fix
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
