Sponsored by: CARiD
rear diff removal
Old Apr 14, 2012 | 09:22 AM
cap85's Avatar
rear diff removal
i am removing my rear differential and was wondering if this was just bolted down...i don't see anything else holding it down but don't want to damage it when removing since its on there tight..might just be all the dirt around it
Old Apr 14, 2012 | 09:23 AM
cap85's Avatar
sorrry, i couldnt rotate it
Old Apr 14, 2012 | 09:26 AM
cap85's Avatar
better image
Old Apr 14, 2012 | 09:39 AM
toyota4x4907's Avatar
You need to remove the axle shafts that are inside the axle tube.
Old Apr 14, 2012 | 09:41 AM
cap85's Avatar
i did that already
Old Apr 14, 2012 | 09:43 AM
shaeff's Avatar
This.
Unscrew the rear brakelines from the wheel cylinders. Use rubber vacuum caps to prevent fluid loss. Then remove the four bolts holding each axle in place, and slide each out. Be careful not to ruin or chafe the axle seal (otherwise you end up with gear oil leaking).
Once you've removed the axles, pull the ABS (I don't know anything about that as I don't have it), then when you remove the nuts/bolts from the 3rd member it should come out with a few taps of a hammer. (not around the bolt holes)
Old Apr 14, 2012 | 09:46 AM
No need to remove the ABS sensor unless you want to. Just unplug it.
Old Apr 14, 2012 | 09:48 AM
cap85's Avatar
That's kinda what I thought.its covered in dirt so I will clean it up so I can actually see where to unplug it. Since its stuck on from being old,are there any tools I could use to help?
Old Apr 28, 2012 | 05:51 AM
cap85's Avatar
how tight does the drain need to be? i didnt see any torque specs for it but remember it being pretty tight on there when i removed it
Old Apr 28, 2012 | 05:58 AM
wii_tarded's Avatar
I had to loosen my sway bar to get the top of the third to slide out. NOTE: USE A JACK!!! That thing is heavy especially when laying on your side and can only get one arm under it to support its weight.
ask me how I know
Old Apr 28, 2012 | 06:01 AM
cap85's Avatar
i already did the hard part and resealed it with rtv but wasnt sure how tight the drain plug needed to be before i fill it will oil..thanks!
Old Apr 28, 2012 | 07:12 AM
Miyoda's Avatar
I went hunting for it in the FSM but couldn't find it. But I know I read it somewhere as I did my differentials last year and it was surprisingly little, 19 ft/lbs?
Old Apr 28, 2012 | 07:18 AM
cap85's Avatar
i searched through that and my chiltons but didnt find anything...i couldnt imagine it would be too much higher than that. i wish these manuals were more specific
Old Apr 28, 2012 | 07:39 AM
BMcEL's Avatar
36ft/lbs:
http://personal.utulsa.edu/~nathan-b...35differen.pdf
Bookmark this link...it has all the torque specs and everything else you need to work on these trucks:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Apr 28, 2012 | 08:44 AM
scope103's Avatar
Somebody took your truck to a "quickie" lube place at some point in its life. The one thing those guys fear the most is having a drain plug come loose, so they use the biggest gorillas with the biggest wrenches down in the pit. And since the drain plug has a fairly large head (24mm?), getting a big wrench is easy.
Don't be a gorilla. Put it back on with the right torque. It won't seem like a lot, but that's how they do it at the factory.
Old Apr 28, 2012 | 10:24 AM
cap85's Avatar
Originally Posted by BMcEL
36ft/lbs:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/suspensionandaxle/35differen.pdf
thanks!
Old Apr 28, 2012 | 12:00 PM
cap85's Avatar
36ft/lbs:
the filler plug is 36ft/lb....couldnt find anything for the drain plug....maybe it just needs to be really snug??
Old Apr 28, 2012 | 12:20 PM
BMcEL's Avatar
Fill and drain plugs are the same torque.
Old Apr 28, 2012 | 12:28 PM
cap85's Avatar
alright..good to know!! thanks.
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
icentropy
Jul 14, 2015 10:23 AM
TokyoD23
Jul 12, 2015 06:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
