Sponsored by: CARiD
vacuum switch valve info
Old Feb 23, 2012 | 07:34 PM
mpwarfy's Avatar
I have been searching online as well as this site but i cant seem to find the answer im looking for. I am hoping maybe someone can help me out. I have a 1988 4runner DLX with a 22re... tonight while i was replacing vac lines i broke my vsv specifically the plastic tube that the hose connects to leaving one only 1 of the 2 hoses connected and i cant find anywhere to get a replacement. i saw that the part might have been discontinued from what i have read this thing has something to do with the air conditioning which i don't use because it doesn't blow cold but how important is this gadget? can i drive my truck until i can find a replacement? are any other years or models compatible? is it called anything besides vsv/vacuum switch valve? any advice would be wonderful unless its grammar related. thanks!
Old Feb 23, 2012 | 07:42 PM
4Crawler's Avatar
If it is the A/C VSV, just block off the two lines (from and to) the VSV and it'll be fine. I did the same on my power steering pump valve:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/13.html
All that valve does is bump up the idle speed when the A/C is running. If you don't use A/C, then it serves no purpose.
Old Feb 23, 2012 | 07:58 PM
mpwarfy's Avatar
cool thank you. that is it. it looks just like that. As for a replacement I am just s.o.l im guessing because i cant find one.
the1998sr5
15
Jul 14, 2020 08:35 PM
montanatruck
Feb 26, 2017 07:07 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
voiddweller
Jul 15, 2015 03:56 PM
