Sponsored by: CARiD
Oil questions
Old Apr 19, 2012 | 10:49 AM
GRINDER32's Avatar
Oil questions
Ok before everyone blast me like they usually do on questions like these, give me a chance.
I have a 88 22re 4x4 and I want to change oil in my tranny, T-case, and diffs. I have searched forums for hours and cant find anything on the 22re, its all V6 info. I do not have a manual with my truck and I need help.
Correct me if I am wrong but I think I am going to
A.) Put MT-90 in my transmission (how many quarts??)
B.) 75W90 in my transfer case (how many quarts??)
C.) 75W90 in my diffs (how many quarts??)
Old Apr 19, 2012 | 11:10 AM
Bassmastry101's Avatar
Fill until the oil comes to the bottom of the fill hole. You will be able to feel it with your finger.
Old Apr 19, 2012 | 11:12 AM
gennro's Avatar
Diffs hold about 2.5qts and the trans holds about 3.5 qts
Old Apr 19, 2012 | 12:42 PM
MudHippy's Avatar
A.) 3.2 quarts.
B.) 1.7 quarts.
C.) Front 1.7 quarts, Rear 2.3 quarts. And the FSM recommends SAE 90 or 80W-90 GL-5 for both.
D.) All found in the 88 FSM.
Old Apr 19, 2012 | 01:20 PM
RAD4Runner's Avatar
See page MA-13 of FSM
Manual transmission oil: 75W-90
Transfer oil: 75W-90
Differentials: 90 in warmer climes, 80W-90 in cooler climes
Someone also brought up a good point: Use same oil in MT and transfer case, in case there's a leak between the two.
PO probably did not drive in 4WD enough that it seems like my front diffferential seals are a little dry. Now shopping for straight 90W; thicker so less likely to leak.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
