Sponsored by: CARiD
trouble restarting when warm..
Old Feb 4, 2009 | 07:44 PM
jhershner11@mac.com's Avatar
So my 95 4runner starts up just fine when cold. No problems there. If I try to restart it while still warm, within a half hour or so of turnning it off, it runs rough, and almost stalls, or will stall. I am figuring on the fuel pressure regulator, but Im open to any suggestions. I have had this problem with my other toyota as well (1986 toyota van) Others suggested the fuel pressure regulator on that one as well, but sold the van before diagnosing it.
Old Feb 4, 2009 | 08:34 PM
toyota4x4907's Avatar
The cold start injector might be spraying when it shouldn't be.
Old Feb 5, 2009 | 08:22 AM
cold start injector was just replaced.
Old Feb 10, 2009 | 09:48 PM
DIRTYBOYZRACIN's Avatar
Injectors could be dirty and leaking down essentially flooding also check ure tps my done the same thing
Old Feb 11, 2009 | 03:47 AM
poynter's Avatar
O2 sensor?
Old May 18, 2010 | 10:25 AM
manasty's Avatar
I recently started having this problem. I have a 2000 SR5 4runner with 180K. When I drive for at least an hour or so and stop somewhere like a gas station for 5 minutes, it will stall out when I try to restart. After a couple tries it will eventually restart. Anyone else have more knowledge on this. Should I go ahead and try replacing the fuel pressure regulator?
Old May 19, 2010 | 01:35 AM
Ron Helmuth's Avatar
manasty welcome aboard and your ride is a 3rd gen Runner while the Original Poster (OP) is a 2nd gen Runner.
That's a thread hijack and don't be scared- this is Newbie Tech and no one is going to yell at you for posting your own thread. In fact feel free to post in the appropriate Tech Section specific to your ride. For you that would be 3rd Gen Runners 96-2002. The solve for you may or may not be the same as the OP's issue.
now back to jhershner with the mac. I had similar issues with my 95 back in the day. It is very much like a symptom of 'flooded' if you ever had a carbureted vehicle. Next time it happens get the hood up and sniff around for gasoline odor.
I believe the fix for me was an actual O ring somewhere but the specifics escape me here in the wee hours of Weds AM.
Let us know where you are via your name or signature-see how even manasty lets us know he is in Chicago under his sign in (left side of screen page) and you can see where I am at in same area.Some specifics of your ride-like the engine in question-are posted at bottom. You can see my mini novel below my post -so folks know at a glance that I am discussing my V6. You might have the 3slow or the coveted 22Re motor to get back to specific to your situation.
Folks are better able to help you if they know where you are-could be one of our fine members right down the very street from you will take a lunch break to help you out. They have done it for me, folks are really helpful here.
I want to say it was a fuel injector O ring that was letting just a bit more excess fuel drip after shutdown but get some other opinions before you just go throwing parts at it. I am no mechanic and not pretending to be....
A lot of the regulars avoid Newbie Tech so feel free to re-ask in your specific section (2nd gen Runners) 90-95 model years.
Longbed 90
Mar 11, 2019 12:38 PM
voiddweller
Oct 2, 2015 07:47 AM
Matthew Perez
Sep 28, 2015 05:43 PM
Boomer8404
Sep 17, 2015 07:59 AM
128keaton
Sep 3, 2015 05:09 PM
