Sponsored by: CARiD
duel transfer cases
Old Jan 30, 2009 | 12:26 AM
eich75's Avatar
duel transfer cases
ok, this is an extremely newbie question (give me a break i'm only 18 ha ha) but what does it mean to have two transfer cases? is it like controlling both axles independently? or just i lower crawl ratio? ha ha excuse my stupid question but i'm curious
Old Jan 30, 2009 | 05:05 AM
JackKnife's Avatar
Technically, the term dual transfer case is incorrect. It's actually a dual reduction box.
Simply put, one puts a reduction box from one transfer case in front of another transfer case. This gives the vehicle four configurations of transfer case gearing. (High-High/High-Low/Low-High/Low-Low)
So, yes, it is for lower crawl ratio.
Old Jan 30, 2009 | 05:26 AM
dropzone's Avatar
Fossilized
you do need an adapter. I used two 21 spline case, 23 spline are stronger. you can convert a 21 spline to 23 spline by changing the out put.
Mine is just getting finished up, but I can tell you it is kind of cool turning my input shaft 11 times and having the output shaft only turn once when in double low (2.28 front case*4.7 in rear case)
left over parts:
nice thing is that is gives you 20 forward speeds and 4 reverse, lots of options.
Roughly it runs about $1000 give or take (depending you where you get parts, etc)to get a dual case set up;
you need 2 TCs (top shift, gear driven (usually)), an adapter, crossmember, shorten rear driveshaft, lengthen front shaft
Old Jan 30, 2009 | 10:09 AM
eich75's Avatar
how would i tell if its gear driven or chain driven? i have an 88 pickup as a DD but i also have an 83 pickup as a parts truck for when i save up for my SAS, its got great drivetrain parts, except for the blown engine
Old Jan 30, 2009 | 12:31 PM
tc's Avatar
tc
Generally, if it's a 4cyl, it's gear driven and if it's a V6 it's chain driven. You MUST have a gear drive reduction box for the crawler, but you can mate that to either a gear drive or chain drive transfer case now that Marlin has come out with the MC10 adapter.
Old Jan 30, 2009 | 04:56 PM
eich75's Avatar
do i absoulutly need a 23 spline?
Old Jan 30, 2009 | 05:19 PM
tc's Avatar
tc
Not with a 4cyl if you have the low gears in the rear case.
Old Feb 3, 2009 | 11:19 AM
b/s rules's Avatar
exactly what they said. just remember the dumbest question is the one thats not asked
Old Feb 3, 2009 | 12:16 PM
DeathCougar's Avatar
You can also find all this information on marlins and inchworms websites: http://www.marlinCrawler.com or
http://www.inchwormgear.com
Old Feb 3, 2009 | 02:35 PM
Trustyrusty's Avatar
Why are your transfer cases fighting anyways?
Its DUAL not DUEL...
Old Feb 4, 2009 | 06:16 AM
b/s rules's Avatar
damn thats a good point trusty rusty
Old Feb 4, 2009 | 08:14 AM
eich75's Avatar
excuse me again, i'm new to more modification than just lift big tires, what would be the use of this setup? i understand it helps for rockcrawling and hillclimbs? but where i live, we dont do any rocks or huge hills, just atv paths and old DCNR trails, and lots of mud cuz thats always there even tho we're in a drought most of the time... so would this help me at all? or would it just be a waste of time and money... right now tires and armor are on my agenda before anything
Old Feb 4, 2009 | 08:53 AM
b/s rules's Avatar
rocks and hills need low end torque, mud and ruts need horsepower and traction. dual cases equal MAJOR torque. if your're not crawling rocks, or vertical mountains, i personally would not do dual cases. i'd spend my money on some horsepower mods. small block ford for example
Old Feb 4, 2009 | 08:48 PM
eich75's Avatar
i'm actually thinkin puttin a 3.4 toy in it when i get out of basics, either that or a 4.3 chevy, i'm not a ford guy whatsoever so thats not gonna happen... i'd like to stick with toyota tho, once you put a diff brand engine in it, is it really a toyota anymore? ha ha but anyway, thanks for yall's input, it really cleared a lot up for me, THANKS A BUNCH
Old Feb 8, 2009 | 10:13 PM
devldogs55's Avatar
Watch the whole thing =0)
http://www.youtube.com/watch?v=JFk9yVwVLrE
Old Feb 8, 2009 | 11:19 PM
Thats not something i would personally suggest ever doing, but thats the general idea. Super low gearing, so you can crawl over obstacles.
Old Feb 9, 2009 | 09:09 AM
tc's Avatar
tc
Note that he has triple 4.7's or something ridiculous in there (because he can)
Old Feb 9, 2009 | 10:34 AM
annoyingrob's Avatar
"duel transfer cases"
I have dueling banjos in my head now.......
Old Feb 9, 2009 | 11:00 PM
eich75's Avatar
ha ha yeah, i was typin that and i new it didnt look right but i didnt remember how it was spelled ha ha
Old May 1, 2009 | 05:39 PM
hodgepodge79's Avatar
With regards to changing driveshaft length, I thought I read somewhere that an IFS truck/4runner could swap the rear shaft to the front, and the front to the rear...
is that right? or am I totally crazy? I've tried searching here and pirate and couldn't find it anywhere.
