Sponsored by: CARiD
frayed belts
Old Mar 6, 2009 | 11:01 AM
jpshreve's Avatar
Question frayed belts
I have a 1996 4Runner with frayed belts. The engine is a 5VZ FE. How do I loosen the belts? Which pulley? How many bolts?
Thanks.
Old Mar 6, 2009 | 11:11 AM
DeathCougar's Avatar
Which belt are you trying to get off?
The alternator belt is loosened via the alternator. 2 Bolts
The PS Pump belt is loosened via the PS Pump, again 2 bolts.
The AC pump belt is loosened via the tensioner assy. One nut that you loosen, then the adjuster bolt you turn to loosen the pulley.
Old Mar 6, 2009 | 12:11 PM
jpshreve's Avatar
I need to remove all three. On the PS pump, I loosened two bolts but can't move the pump or pulley. Just stuck maybe, or did I loosen the wrong two bolts? Both bolts were in front of the engine behind the pulley.
Old Mar 7, 2009 | 12:19 PM
874runner's Avatar
if you post pics it might be easier to explain to you. belts are a pretty basic thing to do. do you have a book for it? the haynes manuals are very discriptive on things like that.
Old Mar 9, 2009 | 08:04 AM
jpshreve's Avatar
Thanks for the response. As it turns out, I found someone who knew how to do it. They weren't here in person, but they walked me through it. The new belts are on!!
Thanks again.
primordialbeast117
Dec 19, 2015 12:23 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
moparbay
Sep 3, 2015 12:48 PM
