Sponsored by: CARiD
how much lift till u need longer driveshafts
Old Feb 17, 2009 | 05:47 PM
buckweat84's Avatar
Question how much lift till u need longer driveshafts
i have an 84 totota pickup i have been working on every now and then i was just wondering how big of a lift can u put on it untill u have to buy longer driveshafts?
Old Feb 17, 2009 | 05:53 PM
airmen65's Avatar
My buddy just lifted his 83 about 2.5 to 3" and his front drive shaft would not even reach together. the rear you should be able to get a few more inches out of.
Old Feb 17, 2009 | 05:56 PM
84YotaBuck's Avatar
I have 4 inches of lift on my 84 and no problem with the length of my driveshafts, have never had one slip out while wheelin.
Old Feb 17, 2009 | 06:05 PM
airmen65's Avatar
Actually after some more thought i know for a fact they run different rear driveshaft set up on the extra cabs, they put in a carrier bearing to bring the shaft back further up near the body before coming down hence lowering the distance it travels.
As for front shafts they may have switched to a longer one between 83 and 84, all i know is my 85 has a longer front driveshaft than the 83. haha, hmm that wasn't much help, but sounds like you can fit 4" though
Old Feb 17, 2009 | 06:08 PM
4Crawler's Avatar
A lot depends on the type of lift spring. When I put on an off the shelf 3.5" lift spring, I had no issues with drive shaft length. But when I reworked the springs for more flex and especially when I moved the front axle forward about 3/4", I had to get the front shaft lengthened. A drive shaft spacer is always an option if you need to make the shaft just a little longer:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Old Feb 17, 2009 | 07:33 PM
85TurboRunner's Avatar
Not all extra cabs have the carrier bearing some just have a regular 1 piece shaft.
I have a 4" pro comp lift and I have no issues, but like Crawler said if I was to move my axle forward things would be different.
Old Feb 17, 2009 | 08:53 PM
airmen65's Avatar
wow, that seems pretty weird. why would they do that? thanks for the correction man.
Jcrawl94
10
Oct 24, 2015 04:34 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
bobpat
Aug 1, 2015 09:25 PM
Sr5crawler
Jul 31, 2015 12:32 PM
kirkrunner
Jul 27, 2015 07:59 PM
