Sponsored by: CARiD
r to an re?
Old Feb 2, 2009 | 08:59 AM
b/s rules's Avatar
r to an re?
am i understanding this correctly? can a 22r block(87) be converted to fuel injection(parts from a 91 22re)? or did i drink to much at the superbowl party?
Old Feb 2, 2009 | 09:01 AM
scuba's Avatar
Yes
Old Feb 2, 2009 | 09:07 AM
DeathCougar's Avatar
yes it can, the 22R and the 22RE use the exact same block.
Two major things needing swapped are the knock sensor, and the pump pump block off plate.
Other than that, its pretty self explanitory.
Old Feb 2, 2009 | 09:12 AM
b/s rules's Avatar
damn thats quick. i kept the wiring harness in my truck but put a 22r in it (it was cheaper at the time). i've got an "re" with a rod hanging out the side, i can take the intake off that and put it on my 87 r? any complications with doing this?
Old Feb 2, 2009 | 09:16 AM
mudcrasher's Avatar
everything is the same as long as you have the lasser block. your head should be the same as well. i am doing the swap right now and not haveing any issues other than i had to find a replacement oil pan due to my 22r coming out of a 2wd truck.
Old Feb 2, 2009 | 09:19 AM
b/s rules's Avatar
i've got a complete re engine"blown" for parts. but my "R" has a brand new head on it, can i use that as well? just bolt up the intake and such?
Old Feb 2, 2009 | 09:34 AM
scuba's Avatar
Yes, Youve got the idea, It's really not a hard swap, granted you somewhat know your general mechanics, like it sorta seems you do. Like DeathCoug said, The knock sensor and pump block off plate are the 2 things not to forget aboot.
Old Feb 2, 2009 | 09:37 AM
algranger's Avatar
there are some good threads on here that will tell ya all you need to know
Old Feb 2, 2009 | 10:20 AM
b/s rules's Avatar
i have a pretty good idea of whats going on here. i'm going to start on this asap. we got slammed with a major snow and ice storm this past week, we've been out of electric since last tuesday night. so we've been wheeling alot and drinking alot more. i got some great pics i'm loading on here tomorrow. but anyway guys, pre-shate "thanks" for the quick responses, as always you all are always on your toes. have a good one and keep the rubber side down
Old Feb 2, 2009 | 08:42 PM
mudcrasher's Avatar
as long as you have the square port 22r head you can use it. if its the round port your efi intake will not work so you will need to swap heads. but if you pulled the 22r out of an 87 toy you should be fine.
Old Feb 3, 2009 | 03:33 AM
b/s rules's Avatar
yes it's an 87 engine, and pretty sure it's square port. i had the head rebuilt before i put the motor in, with all the goodies, so i would really like to be able to use it.
Old Feb 3, 2009 | 09:38 AM
mudcrasher's Avatar
yup you should be good to go then. another thing i also thought of is the brackets on the bottom sides of the engine that the trans bolts to you might need to swap. mine was from a 2wd auto and the brackets didnt have threads as the 2wd autos have the threads in the trans unlike the 4wd 5spd. you can just swap the brackets or get longer bolts and through bolt them. i through bolted cause my old brackets were toast after the rod busting out the side of the block and breaking them in pieces. just make sure you use grade 8 or better.
Old Feb 3, 2009 | 11:06 AM
b/s rules's Avatar
i'll check on that, but what do those have to do with swapping an intake? i know what brackets your're talking about though. i've got the block off plate off the bad engine, but not sure on the knock sensor. where's that located at? i'm just glad i kept all my wiring harness in tack and tucked away. i'm using my factory fuel tank i just relocated it behind the cab (no bed) and unhooked the fuel pump, kept that wiring too! so from all the info i've gathered so far i think i should be in good shape. but if i run into any problems or questions i think i got some fellow yota-ers that can steer me in the right direction! thanks again guys
Old Feb 3, 2009 | 09:25 PM
mudcrasher's Avatar
the knock sensor sits just above the oil sending unit under the intake. there should be a threaded hole all ready in the block.
i was thinking you were swaping a 22r into a 22re truck and just adding the 22re intake. but now that i look i see you are running a 91 with a 22r motor. so no need to worry about the brackets.
Old Feb 4, 2009 | 06:14 AM
b/s rules's Avatar
yeah, i've got a bad ass 22r but now i've got access to a "re" top end. and if i could use the intke and such to make it fuel injected it would be even more "bad asser". i check into the knock sensor and get it straightened out. thanks mud crasher
