Sponsored by: CARiD
What the heck is this??
Old Jan 25, 2009 | 08:26 PM
BLATT13's Avatar
I have a 1991 pickup and when i bough the truck the owner said i had to turn a switch on every time i put it into 4 wheel drive. the switch is located on the left side of the steering wheel and has a red light that glows when the switch is on. so as he told me to i do, but if i turn the switch on if its not in 4 wheel drive it makes a squealing noise. what the heck is this switch for????
Old Jan 25, 2009 | 08:28 PM
tc's Avatar
tc
It ain't factory, I can tell you that much ... The only factory switch that looks anything like you describe is the clutch-start-cancel (which is what it says on it) and it wouldn't make anything make a noise for sure.
Old Jan 25, 2009 | 08:32 PM
scuba's Avatar
Does it have ADD..?
Old Jan 25, 2009 | 08:34 PM
BLATT13's Avatar
Automatic Differential Disconnect?.....i have no clue , should it?
Old Jan 25, 2009 | 08:39 PM
89silverpu's Avatar
No does the truck have ADD? (Attention Deficit Disorder)
I'm super funny I know. haha
Old Jan 25, 2009 | 08:46 PM
intelplatoon's Avatar
i thought so....
Old Jan 25, 2009 | 08:49 PM
BLATT13's Avatar
i just checked, by the look of the hubs it does......can someone explain to me what ADD does and why it would squeal if its not in 4WD
Old Jan 25, 2009 | 08:51 PM
BLATT13's Avatar
as well as should all 91's have this?
Old Jan 25, 2009 | 08:52 PM
89silverpu's Avatar
No, some came with manual locking hubs which must be engaged by turning a dial on each hub.
Old Jan 25, 2009 | 08:56 PM
BLATT13's Avatar
sweet...thanks guys
Old Jan 25, 2009 | 09:02 PM
scuba's Avatar
I knew that was coming ...
Old Jan 26, 2009 | 03:51 AM
GSGALLANT's Avatar
You should still find out what that switch does, because as others have mentioned, it's not stock. Follow the wires from the switch to see where they go.
Old Jan 26, 2009 | 04:25 PM
dropzone's Avatar
Fossilized
where is the squealing noise coming from? wonder if it is a homebrewer e-locker set up...
Old Jan 27, 2009 | 12:47 PM
Jay351's Avatar
Trace the wires. Nothing in the front end should squeal while in 4wd....
You probibly have the A.D.D and your hubs are just flanges... Mine were, till I swapped in manual hubs.
Old Jan 27, 2009 | 02:07 PM
BLATT13's Avatar
no...it squeels in 2wd if i turn the switch on....it doesnt make any noise while in 4wd
Old Jan 27, 2009 | 02:16 PM
flashkl's Avatar
Old Jan 27, 2009 | 04:02 PM
92yotaman's Avatar
!!!I have this same switch on my truck and i was so confused because it never does anything. Course my 92 has a SA. Im glad i saw this because i want to know too
dzldust
7
Oct 6, 2015 05:39 AM
adamk
Sep 24, 2015 03:59 AM
adamk
Sep 23, 2015 03:24 PM
dropzone
Sep 13, 2015 11:18 AM
digdug40
Aug 28, 2015 02:24 PM
