Sponsored by: CARiD
Somethings 'missing'; potential clutch problem??
Old Jan 26, 2009 | 06:06 PM
JZM's Avatar
JZM
About a month ago my '97 Tacoma (3.4, manual) started skipping/hesitating. Say I'm turning a corner at a slow speed in 2nd or 3rd gear and then start to accelerate into the straight, it will start to jerk until the RPM's get up and there is less load.
I started to think it was the clutch slipping; I do often pull heavy loads (too heavy for this truck, including construction equipment and 4 cross-country moves with cargo trailer and bed at full capacity). The truck idles fine and when it is running at 2500-3000 RPM is it smooth. It's only when there is too much load or too high of a gear. For those reasons I ruled out a fuel problem. Could be the tranny??
I would love to have some suggestions from you guys because the nearest reputable Toyota mechanic is 2 1/2 hrs away.
If it is the clutch, what am I looking at in terms of cost to replace. I understand I can get an OEM clutch for a couple hundred $$, and I know labor rates vary, but what kind of time frame, etc...?
Thanks for the help.
Regards, Jarrod
Old Jan 27, 2009 | 06:12 AM
83's Avatar
83
Not positive if it's the clutch, mine have always slipped by making the engine rev up but not gain speed, but in a smooth, not jerky way, so I can't be sure. As far as the rates and time...a good clutch will only run you around $200, but the labor will be at least that much. I'd say if the shop can get right on it it could be a 1 to 2 day job.
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Avenged
Jul 9, 2015 07:55 AM
wilbertd
Jul 6, 2015 07:39 AM
ptb12
Jul 5, 2015 01:49 PM
