leaking 88 4x4 pickup
my 88 SR5 Pickup is leaking oil in the front of the engine, does not look like a crankshaft or cam seal. There is a lot of oil under the intake manifold could it leak oil from that gasket or is it a headgasket?
just put valve pan seals a few months ago. would you be able to tell if there was a hole in the block would it run bad? what do you mean by a timing cover? Its leak a little before just about a hand size puddle. the other day i went to work and at lunch i notice a big puddle, i put more oil in it started it and let it run, seem to leak more when running. look like it came right down from the crank shaft, I can really see if its leaking.
Regency
20
Jan 3, 2020 07:43 PM
