Sponsored by: CARiD
96 Toyota 2.7
Old Feb 9, 2009 | 01:53 PM
swampdonki's Avatar
96 Toyota 2.7
Just had a question about my 96 Tacoma. I have recently put a new head on and just finished buttoning it up. I fired it up for the first time and it revved up to about 3,000 and then dropped down to a normal idle 800 or so. Then it started spiting and sputtering then died. I checked the maf then the tps and after that I checked the egr and the thing right next to the egr that has the filter. None of which seems to be the problem with the rough idle (I actually bought new sencors and tryed them out). So then I began checking for a vacuum leak. I found a few cracked lines but nothing big. I replaced the bad lines and still rough idle. Then I proceeded to check for a mechanical error. I removed the head maid sure I was on tdc then put it back on ensuring that the cams were in time and then checked to make sure the distributor was correct. Put it back to gather and still the same problem. Does any one know where to start looking?
Old Feb 9, 2009 | 10:53 PM
scuba's Avatar
for ya, Im not too sure so im not gonna spit out an answer, Someones gotta know.
Old Feb 10, 2009 | 07:19 AM
swampdonki's Avatar
I think it might be the exhaust. I have installed a header and well it has never quite sealed yet.. It sounds like straight headers. Well i was sick of that so i got down there and added 4 gaskets to it and it sounded even worse than before and through up an engine code. (po300) multiple cylinder misfire. So at first i was pissed. And started looking to the fuel rail and what not. After i checked the injectors i decided to remove the 4 gaskets and put 2 back on and this time i spent 20 minutes lining it up and trying to get it on good. I started it up and it ran ok it still had an exhaust leak but it was not as bad as before and it ran good enough to drive, and didn't throw any engine codes. So i think if i can button up the exhaust good enough it should run.
Old Feb 10, 2009 | 10:12 AM
scuba's Avatar
Never really heard of a truck not running because of an exhaust leak...Ps. in your tags, Its : 3rzfe
Old Feb 11, 2009 | 08:01 AM
swampdonki's Avatar
Ok so the exhaust was part of the problem but not the solution. I kept on working on it last night and heard a leak between the injectors and the injector spacers. So I sprayed it with chemtool to see what would happen, and when I did it killed the motor. I have removed the throttle body and the fuel rail and began working on the spacers. I put a larger o-ring on them and then added a bit of RTV around the top lip of it to help seal them. I am letting the RTV dry and hopefully tonight it will be running properly.
Old Feb 11, 2009 | 08:16 AM
scuba's Avatar
Sounds good, weird no-one could pin point it a bit more...Post up when you get her runnin right. Good luck !
Old Feb 11, 2009 | 08:44 AM
swampdonki's Avatar
no joke i was really hoping for help on this websight and you were the only one with thoughts on this issue.
Old Feb 12, 2009 | 07:03 AM
swampdonki's Avatar
Well... It runs!!!! I had to add an o-ring on the outside of the injector and lower the fuel rail just to get the injector to seal to the injector spacers. However it worked and it runs better than before. I will try to post some pictures of the project later next week.
Old Feb 12, 2009 | 08:38 AM
scuba's Avatar
Sweet Glad to hear !! Trust me about this, You can get help on alot of things on here, Thats why im reaalllly surprised no one else offered their thoughts.
Old Feb 16, 2009 | 09:11 PM
swampdonki's Avatar
pictures
pictures
Attached Thumbnails 96 Toyota 2.7-crack-head.jpg   96 Toyota 2.7-iphone-photos-changing-parts-head-head-008.jpg   96 Toyota 2.7-iphone-photos-torque-new-head-005.jpg
Old Feb 16, 2009 | 09:42 PM
swampdonki's Avatar
the 2 heads, moving pieces from one to another
cutting down the water pump bolts
Torque the new head in place
Cam timing
progress
rechecking the timing
injector spacers with permitex to seal them
injector o-ring
bury final assembly
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
